Posi-Twist Connectors (New Electrical Product)
it looks like a glorified wire nut. the only difference being threads...?
i wonder how they would hold up in a high vibration environment.
I think that's where they would excel; that and being more secure and more water resistant. Could even fill the one end with silicon to make it waterproof.
No doubt someone will say these have been out a long time and they are nothing new. It wouldn't be the first time I was late to the party.
I wouldn't use this in a house but for a car or bike where they get a lot of movement...
I've used the Posi-Tap's before on my truck and boat.
Only used them a few times but have no complaints.
I think I first saw them about 10 years ago?
Thanks for sharing your findings. But I have to agree with other members, they have been around for a while 10+ years.
Wedgy, I have used them on a number of things and they're OK, but not as awesome as I thought they'd be. The idea is cool, but there's a fine line between being hot enough to melt the solder, and being too hot. When that happens, the shrinking of the tube creates a geyser of molten solder out of the hole you melted in the side of the tube.
Use these a lot and really like them.
Sounds like you need a heat gun that uses an adapter to direct heat to a specific location vs all over. I've been using these type of connectors for a while and have never had any issue with melting through the shrink tubing. Additionally, for further waterproofing and coverage, I always use separate shrink tubing over the connector that covers wire to wire.
As per the connector in the original post, I think these would be great for some low voltage home applications, but I don't think they'll stand up to exterior truck use and are quite bulky to use for interior of the vehicle where you usually have to tuck the wire behind a panel or out of sight. Plus, constant vehicle vibrations, over time, can always jar something like this loose. A soldering connection with some shrink tubing or tech-mesh usually prevails in this area. If I want a waterproof and quick connection for exterior use I'll stick to using a Deutsch connector.
(ps, moved to off-topic)
I have those waterproof ones and honestly think they are not that great. Half of the time you cant direct the heat properly and end up with a crappy joint. Or damaged heat shrinking. Seem to work a lot better in the smaller gauges of wires. I rather just solder the joints of wires and then slide heat shrink over the exposed soldered surface and shrink it down. :)
Sent from my SM-J337V using Tapatalk
When I saw the video the first thing I thought was that must be some really tough shrink tubing or very low temp solder. I just solder then shrink tube after.
BillM777
