Post your LIFTED pix here!
AH yes nice man, I see you had the rings setup at max, did you do anything else besides the UCA's ?
I want bigger tires and higher lift lol but missing the mooooolah hehe !
What you got now? I think anything higher you will have to do a drop bracket lift
Is this a 3inch lift with 20's? What's the specs on the rims and tires? And does it rub?
Yes. .3"lift fronts & 2"lift rear, yes those are 20x9s but just sold them..now im running a new set up.
Hi man lift is in my sig. but I won't do anything until the new 4Runner comes out with a new engine. And if its a lower powered one like the new Tacoma then I will probably cry first then check my options :)
And then maybe get a Tard Pro and mall crawl in Montreal as I would be the only one with a Pro in Quebec lol.
2013 Trail
Kings Coilovers front and rear
Total Chaos UCA's
ToyTec Superflex RCC2.0 Rear Coils
SCS model 6
285/70/17 Falken ATW3
Body Mount Chop
Fender Liner mod
Do you need to replace Upper control arms to run 20s" with 3" lift to avoid rubbing ? Are your tires size for the 20"? I just orded the spacer lift kit 2.5"/1.5" and want to run larger wheel sizes instead of sotck 17". Btw, mine is 16' SR5.
Anyone has link to a DIY 5th gen 4runner with Daystar 2.5"/1.5" spacers lift installation? i ordered mine and it will be here next week. Any links or instruction would be greatly appreciated. Thanks.
Naw, i didnt need to replace my stock UCAs with my lift and 20" wheels, although it is recommended but not a must.
2013 Trail
Total Chaos UCA's
SCS model 6
Body Mount Chop
Fender Liner mod
Did you have to do the BMC for this setup to work? Looking to get super similar setup but with the SR8s.
T4RZAN - that lift with that tire combo looks great!! I don't know why I keep torturning myself looking at lifts when I am trying to avoid one this time around. LOL. They just look so bad a$$!
Front: Icon coilovers with All pro upper control arms.
Rear: wheelers off-road T12 eibach springs with 5100s for now.
Sent from my Nexus 6P using Tapatalk
2016 4Runner with KDSS now sports a modified Fabtech 6" suspension system with FOX 2.5" remote reservoir front coil-overs and 2.0" remote reservoir CD adjuster rear shocks. Toyo Open Country R/T 35X12.50R17 tires on Fuel Offroad JM2 wheels. Built by RSG Off-Road in Colorado.
IMG_0056_zpsnctlg0gf.jpg~original
<br>
<br>
<br>
IMG_0064_zpsx5mwwf1i.jpg~original
<br>
IMG_0072_zpssxbpdpen.jpg~original
<br>
IMG_0067_zpsjb75msqb.jpg~original
<br>
IMG_0070_zpsg6qvddty.jpg~original
<br>
What is the modified fabtech? Do you have specific specs? I just added 2.0Radflo extended travel c/o w/ rokmen uca 5160 rear with ome medium load. had thought about going higher. Did you do add-leaf in the rear plus spring?
