Post your LIFTED pix here!
I saw those pictures, pretty nice.
Come to think of it, why do most T4R's only do a 3" lift and not so much a 6" lift? Lack of suspension options?
I'm pretty sure it has to do with IFS. Lifting it over 3" would require drop bracket lift. Whenever you're lifting you rig, the purpose is to gain clearance, not drop the diff. Tires make up for some though. And to be able to stuff 35s would require lots and lots of cutting and hammering.
Thanks for the info..
Basically, if going over 3" lift you would need much bigger tires and to get bigger tires, bigger tires needs cutting and trimming?
Excuse my ignorance.
Hopefully in time, they'll come out with a full 6" lift kit.. I'm sure we can fit 35's if we reeeally tried :)
I wouldn't want a 6 inch lift of they made them as some off camber trails had me puckered a few times and probably would have rolled it already with a 6 inch lift which raises the center of gravity. It would be alright if you were cruising the swamps on flat lands.....or for looks.
You can fit 35's with a BMC,creative caster settings and plastic trimming now if you don't actually wheel it and stuff the tires . Mall crawling or for looks should be fine though.With 35's you are going to be tearing stuff up in the wheel wells or the tires themselves like I did offroad as our wheel wells are smaller then FJ's . A body lift would solve the problem raising the wheel wells up but opens up other cans of worms .
These are rub marks on the top of my front wheel wells from the tires hitting when stuffed and I'm running KM2 305/70/17's which are actually a little smaller then the 33.9" they claim. I also tore chunks of tire out in the back on the inside edges from hitting the wheel wells.
Picture007-11_zps5aa0ea29.jpg~original
Picture008-8_zps91d115d3.jpg~original
Extended bumpstops?
Just got it back toyotec 3/2 space, ultra gauntlets 17x9 4.5 backspacing with open country at II 265/70/17.
[MENTION=8206]harper7[/MENTION] is spot on in his comments. I am running a similar tire in a more narrow size. I've spent a lot of time trimming, bending, etc to eliminate rubbing but I've only been able to eliminate the major rubbing and their are scars all over my wheel wells from tire rub. I think that a 33-34"ish tall tire is plenty for the runners. Anything bigger and the rubbing will be the least of your concerns. If you were to go bigger be ready to sacrifice your COG, drivetrain reliability, power, safety, etc.
If you really want to run. 35"+ tires. I'd go with a 1st gen Runner or hilux, American pickup, or a Wrangler.
Took a few pictures while up in Bath, ME for work. I really like how you can see the bulky lines on the front fender and rear in the lighting.
