People run spacers so it gives the tires/wheels a wider stance. There is no performance advantage and as mentioned above they worsen tire rub. Don't get spacers unless you want to start cutting or trimming.
I understand what all that means. Just wanted to make sure. Sounds like I'll fine with stock trail rims and 285s. I don't understand the wheel spacers at all... my thought process is why not eliminate tire rub and avoid rock chips and paint damage by keeping the wheels where they should be. If the only reason is looks, no thank you.
Well, it took me over four years to wear out my stocker 265s. Four years of obsessing over lift options and researching on this site. I finally went with the Toytec Ultimate, Spidertrax spacers, TC UCAs and 285 Toyo Open Country ATs.
Many thanks to everyone here who enabled my OCD :lmao: and helped me to make an educated choice. Thanks also to Scott and Shawn at GTPeace for making it happen!
Very nice! What crossbars do you use for your rack? Just the regular 5th gen crossbars on all other models?
TRD Pro with 2" Toytec lift and Nitto 285/70-17 Ridge Grapplers
How long did it take to get your hands on a Cement TRDP? I still haven't seen one in person, but your setup looks awesome.
[MENTION=103801]sn_85[/MENTION] Could you measure the distance from the frame rail to the ground behind the front wheel and in front of the rear control arm?
I'm curious how close to true frame level this setup is. I'm considering a lift but as the 4Runner comes from the factory there is only about 0.25" of forward rake so just about all the popular lifts cause reverse frame rake.
