Louise
Going to lube mine tomorrow. A lot of good info here. Last year I asked the dealer service to grease my zerks. (ooo baby) Sorry! Does the report look to you like they did 9 zerks?
What is your method of applying the lube?
I'm going to use a grease gun. I've picked up a tube of Valvoline Lithium NLGI 2 Multi Purpose grease. I suppose I'll buy a second gun for the Moly grease. I'm going to see if I can get a mini gun & some mini tubes for that. I was thinking of just using the multi for everything but since I've invested this much into the truck there's no sense in cheaping out on the protection.
Are you going to do 1-2 pumps or pump until you see some grease leak out? Not too sure how much to add
Well considering everything I've read here I'll do 2 cautious pumps to the slip yokes, watching for movement but won't over do it and maybe be more liberal with the spiders. I'm going to call my dealer service and see what they say. I will also check them after driving for a bit. I've seen a lot of vehicles run for a long time without people being neurotic about greasing them. I think keeping on eye on them and putting a little in when they look dry should be sufficient.
I work for a little u-joint and driveline company that employs some 30k people in 60+ countries. Our head of QC emphasizes that you must see grease purge from all 4 caps. I have always done the same since 16 years old and never had an issue burning up u-joints.Thanks, appreciate and respect your input, as I've seen a lot of the questions you've answered for members, especially around DIY maintenance. Just wondering about this one in particular cos there are so many different opinions. For instance, over at this thread at ih8mud https://forum.ih8mud.com/threads/too-much-grease-in-drive-shaft.378824/. One guy makes a good argument about why you need to grease until some grease purges from the seal to ensure you're actually pushing grease to the splines. But others talk about how too much can put pressure in the wrong places. I can make sense of both schools of thought. But has anybody actually experienced problems from greasing until the seal purges vs just using 1-2 pumps?
I spoke with a guy at my dealer service center. He said not to put too much grease into the slide yolks. He said the worst thing that will happen is that the grease will fling all over, get on your muffler, and smell really bad. He said if it's your first time doing it you'll probably overfill it, smell it and realize not to put so much in next time. I asked him about filling the spider yolks to the point of purging out the old grease and grime and he said yes that's what they do. I also asked about the importance of using the molly on the slip yokes and he said if your greasing your axle shafts your ahead of 99% of the people out there and you don't really need to worry about that.
So as I suspected as long as you're keeping an eye on them and keeping lube in there they should be fine. I am going to use the multi-purpose lithium grease on everything and just make sure I keep them lubed on a regular basis. I'm going to be doing a lot of traveling and the grease gun is coming with me so not having to carry two just makes things that much easier.
I hear customers tell me that if you add too much grease the bearing cap seal is permanently broken, etc. They don't know what they are talking about. Not the case for u-joints at all. But you don't want to blow the DS dust cap off when greasing the slip. That's the one where enough is enough. Let the shaft expand a little and call it good. Do it again in another 5-10k if you didn't think it was enough the first time. Then again, it pretty much pops back on if you do blow it. Usually.
Sent from my SM-G900V using Tapatalk
Jeeze this thread is crazy, I do my own service and want to start doing this as well and there are so many GD trains of thought going on here, I don't know what to believe or even do![]()
...Hardest part about the whole experience was getting the damn hose fitting off the zerks. Even punched myself in the face pulling one off. LOL
Hypothetically, how many miles can one drive before doing this grease service? I asked a number of dealers and they said that they dont have grease guns even and in nyc there isn't a place to do this service myself such as in a driveway. Also, i do not do any off roading so not sure if that helps with extending the service interval.
Which is why I bought one of these:
https://locknlube.com/products/lock...h_1rfMGBUzD04wS3TC64RAicHuWz_AOEaAjS7EALw_wcB
Much less painful than replacing a zerk fitting.
According to the maintenance manual every 5000 miles.
