Pushing the towing limit...
PWRHungry
I'm considering a boat that when fully outfitted would weigh in at close to 7000 lbs, without the trailer.
Think my V8 4Runner with upgraded hitch and weight distributing apparatus could do the occasional careful towing trip?
Am I gonna be forced to get a Tahoe? ;)
I've never seen a boat trailer with a weight distributing hitch, because they all have surge brakes. The brakes would not work with that type of hitch. In that case, your 4Runner is only rated for 5,000# weight carrying & 500# tongue weight.
I tow 5,500 with a weight distributing hitch with ease.
To try it, you would need self leveling or air shocks to keep your back end from dragging.
Good luck
Could be hilly, but not certainly not mountenous(along the east coast). I'm sure I could move the thing a short way but wanted to know whether a decent distance would destroy the 4runner, me and the cargo ;)
Sounding like I may be outa luck.
WHich year do you have? Mine is rated at #5000, but the 04 were rated at #7000.
I dont think the engine will be a problem and your tranny will warn you when it gets hot. So you should be fine if you have an 04.
Edit: I missed the trailer part, so the boat already weighs #7000. That would be pushing it, depends how much you want to push the safety limit but it will be able to do it.
There are boat trailers with WD equipment AND surge brakes. The surge brake portion is on a separate, moving portion of the frame.
The Tahoe wouldn't do much better as far as the tranny goes. It uses the 4L60E tranny; the same as used on the S10, Astro, Camaro etc... I had two of them fail on me when maintained properly.
Towing
You tow a trailer loaded over your manufacturer's towing limits/loads and have a wreck and your insurance can choose NOT to cover your stupidity. Fact. Period.
:guitar2:
I'd be concerned with stopping.
You're going to be trying to stop with something almost twice your weight behind you. . .
My boat and trailer TOGETHER weigh 6500 pounds. I would NEVER consider exceeding the rating by as much as you plan on.
Boat = 7000 pounds
Trailer = 1000 pounds or so
Gear (Gas, etc. in boat) = 500 pounds
At that rate you are already WAY over the limit.
I would not do it.
Mike
Consider a Armada? I know it's Nissan but they can tow a wopping 9000# or some crazy number like that!
Anyway, Brian is absolutely correct on this. If something does happen (heavens forbid), you can be screwed by the Insurance Company... I'd say it's definitely not worth it even if you know it's only going to be a short distance.
You might consider doing a rental rig to tow it since it's occational.
You also have to take into consideration that although the specs may say it might be able to haul the load, that doesn't mean your manuverability and stopping abilities are not going to be severly effected. A load that large is going to have a tendency to push around the vehicle just because of the smaller size of the 4Runner. This could possibly be a very dangerous situation.
pax at 4
