Ok, first off this is most likely my fault entirely, but trying to get some clarification.
I have a 2017 Limited with smart key.
Started the vehicle this morning before work as it was brisk outside (Celsius -29 / -41 windchill. Fahrenheit -20 / -41.8 windchill). It was plugged in the previous 13 hours, vehicle starts up, bit of a groan, but it started. I then (here is where it is most likely my fault), lock the doors with the interior door lock, close the door and head inside while it warms up. 10 minutes later I come out, use the fob to unlock the doors - drivers side - and nothing, doors will not unlock. I try the passenger door, rear front and pass doors, rear hatch, the smart unlock door handle. I then remember the the key on the fob, so I resort to trying the key. The key is not working, will not turn at all. So I turn the key 180 degrees, nothing. Key still does not turn. I am trying the fob and key on and off for 20 minutes, then decide to try the second remote. Still nothing. I take the key out of the second fob and after 1/2 dozen or so tries the doors finally unlock.
Toyota told me my lock had to be frozen. Possible I guess, but the vehicle has not been washed for over 3 weeks. Is there any other reason this would have happened?
I imagine the vehicle thought there was someone sitting in the drivers seat when I locked the doors from the inside and shut it, but I also would have thought the fob should have unlocked the doors for me from the outside.
Any advice, thoughts, knowledge would be appreciated.
