Rack removal problem...
1traildriver
I removed my TE rack this weekend and the driver's side rear mounting hardware broke during the removal. I was wondering if this has happened to anyone and how they fixed it? The following is what happened:
Almost all of the rack mounting bolts came out as expected. When I got to the driver's rear mounting bolts, they were very tight and as I was wrenching on them, they seemed to skip and make a plastic snapping noise. Of course they then came loose and I removed the rack only to find that the little while plastic mounting tubes had broken off completely. This left 2 pretty wide holes (a little less than 1/2 inch) with no quick fix at the time. I will have to hit the dealer on Mon or Tue to see if the parts can be installed, unless someone had the same issueand found an aftermarket fix. For now I have duct taped the snot out of it to keep water and moisture out of it.
Pics below.
This pic is from W8kbrdr's thread on the roof rack delete.....this is how it is supposed to look with the plastic mounting tubes showing.
:wow: I cranked the bolts on my Baka rack pretty tight and had no problems. I smell warantee work. Hope you get it fixed!
new2yodarun4her
