Radflo Suspension Technologies Factory Tour for the T4R Forum
The4kbeast
I visited Radflo's manufacturing facility earlier this month in Fountain Valley, CA. Took some pictures when I picked up my new setup and thought I'd share.
Here's a look at some of the work that goes into turning a bunch of tubing into shocks:
ACBA5A0D-1278-4ABD-B30D-AA482AEF4B92-905-000001A867DFCEC3_zps52d279bc.jpg~original
The start of shock/coilover cases:
E8377603-A57F-4F6F-B19C-33CDB3BF38C4-905-000001A8C9441910_zpsfbcbc8bf.jpg~original
A bypass shock is conceived:
760CF373-D328-4A20-AA51-57A4299CBDCE-905-000001A894B1F769_zps3f22a437.jpg~original
Upper portion of coilover with opening for Schrader valve for nitrogen charge:
62465F9B-8714-4EB3-B730-69A5896676A7-905-000001A8E1F7CF2F_zpsb201c2f7.jpg~original
They run dedicated machines for turning out individual components; some manual and others are computer controlled. I think these are going to be spacers for the lower bushing mount:
0C6B230D-88C7-4F14-89BC-E1235328126A-905-000001A915886B49_zps164f41e2.jpg~original
B9852A1A-19B8-45B9-8F7E-920FA6897C5C-905-000001A9356AC01B_zps883a41e9.jpg~original
Threaded shock shaft
3BD72FC6-6169-4950-A4A7-23F3144C36CC-905-000001A948D9D579_zpsa8a0871d.jpg~original
CFC15463-E272-442E-8636-D32218193DBE-905-000001A9653A5FD9_zps4aa9407d.jpg~original
Finished pieces go into stock:
393E4AAB-7296-4D30-8FF8-BD85581E03B8-905-000001AB29A18121_zps9f50eed7.jpg~original
B5A53EEC-8585-43C3-AABD-4BCA58EB3649-905-000001AB8392003F_zps58cf331c.jpg~original
F70BE98F-BA98-42A1-878A-A8A515EB9D96-905-000001AB559776BB_zps6ea0950f.jpg~original
Welcome to assembly:
CEEAE6F1-B590-4AC7-ADB4-161D6BA13487-905-000001AB3B40AC70_zps9a6636b6.jpg~original
1648DB09-7AF9-4BF6-BA22-64FE5CB018C5-905-000001AB63C7FE5E_zps20af41a5.jpg~original
This is also where rebuilds come in:
F773C4C6-3AE3-43FD-905A-7A881FFEB788-905-000001AB72D7F140_zps6a60b393.jpg~original
Shipping:
1E496657-241C-45D9-BF69-633CDCFACDDC-905-000001A816CFD4AA_zps9f2590cf.jpg~original
My 3rd gens new setup, 2.5" cans front and back, fronts are extended length:
033554BF-6CA2-4D62-8AE4-0545D716D9CA-915-000001BA3A7EEEFC_zpsa8bdaf58.jpg~original
Front Coil-Over Shock Details (copied from their website)
Body: Threaded SSID alloy steel tube
Rod: Mirror polished Nitro Steel®
Rod Guide: CNC machined bronze, Teflon® coating
Seal: Combination Quad-Ring® and lip seal, rebuildable
Piston: Radflo aluminum Freeflo™ racing piston
Valving: Self-adjusting, velocity-sensitive deflective disc, consumer or factory tunable
Oil: Radflo high-temp foam resistant suspension fluid
Pressurization: Nitrogen gas, 200 psi
Bearings: Teflon® lined spherical steel
Body Caps & Eyelets: CNC machined 6061 or 7075 aluminum, black anodizing
Springs: Eibach® 14" 650 lb/in coil springs
Coil-Over Hardware: CNC machined aluminum with Nylatron® spring slider
Finish: Mirror polished, clear cadmium plating, chrome optional
Service: Consumer or factory serviceable
2.5" rear shocks:
B7E60F9F-E33D-452D-82D8-89398A3CED9D-915-000001BA15FCEDB5_zps9a391159.jpg~original
Rear Non-Coil Shock Details (copied from their website)
Body: Smooth SSID alloy steel tube
Build/install details will be added to my build thread soon!
DanielShawSZ
