Radiator/Fan shroud replacement
CurseRunner
Having cooling problems with my '92 junkrunner overheating. Haven't hit critical temp since my new water pump/timing belt/radiator flush about 3-4 months ago, but after around 20 minutes of driving, the temp gauge sits close to the red zone.
I'm hoping that a new radiator/fan shroud will fix this. The radiator is the original and definitely a bit rusty, and it has never had a fan shroud since I purchased it. Does anyone have suggestions for a decent radiator that won't break the bank? I'm assuming an amazon fan shroud that is the correct fit should do just fine.
Hopefully the antlers aren't blocking too much airflow.
I highly doubt that the lack of shroud is the problem, but like you said, more on the radiator. I'd check with a local radiator shop. They hooked me up for $75 for a decent alum/plastic radiator.
I recently replaced mine (including the fan) and went with Napa. The radiator is fine, i would buy that again, but the shrouds find a part out or order from Toyota. The Napa ones did not fit correctly I'm searching for junkers to get an OEM shroud to satisfy my OCD.
Phil
Thanks for the info guys. I'm hoping one day to get this truck to the point I can safely offroad it. Feel like I'm living inside the song Johnny Cash - One piece at a time.
