Rear Coil Spacer Question
natevans65
I have the 3" Toytec Ultimate setup with 5100 Billies and coil overs in the front with the front maxed out. I am just shy 2" higher in the front than the rear and am looking to balance it out and was looking at a rear coil spacer to raise it. I was told that you could not do that or it was not recommended but I read on this forum that many have done so with the FJ coils, stock coils etc. I know the simple solution would be to lower the front but I would like to keep it at the higher setting due to a larger offset on the rims and spydertrax all the way around to keep the BFG's from rubbing.
Is there any reason (safety???) that I could not just put a 1.5 or 2.0 spacer solution on the coil to level it out? Thank you for your input....
go for it!!!!! best decision i ever made because i can crank my coilovers up even more! i have 1" rear spaver with 2" lift coils
delislerebecca
