Rear Disc Brake Conversion Kit
got my kit in the mail, it's going to be a bit before I can install but it looks great and am excited to get to work on it! thanks again!!
These were one of the best conversion kit out there for the rear brakes. Not disappointed and have talked them up to people in vegas. Hope you sell the design to someone to continue to make.
Interested in purchasing kit
Here's the long overdue update.
I reported to my new assignment in October, and as is fairly obvious from my absence on the forum, I haven't had a lot of time to work on this project. Take the long hours at work/travel, and the fact that I have young children, it just isn't practical for me to get these kits put together and shipped out. So I've come to the decision that I'll sell the inventory I have and that will most likely be the last of these kits. Thank you for all the great feedback and praise and I hope that this run helped the community.
I have a total of 19 parking brake kits remaining. That will be the limiting item for full kit availability. Once those are gone, I do have a few more conversion brackets that I can assemble brake lines for.
I will give priority to the people who have already shown interest. There are more than 19 people on this list, but there are also a lot of people I haven't heard from in a long time. For the following people, please let me know if you're still interested. I'll also reach out to the people who provided contact information.
[MENTION=141769]Blackdawg[/MENTION]
[MENTION=558149]ACE115[/MENTION]
[MENTION=154086]itskmill06[/MENTION]
[MENTION=564482]AntsyMo[/MENTION]
[MENTION=362585]Xjazzwreck11[/MENTION]
[MENTION=543769]kirkman[/MENTION]
[MENTION=410311]Arad72[/MENTION]
[MENTION=120197]Bdnewyork[/MENTION]
[MENTION=91201]tytacoma89[/MENTION]
[MENTION=104473]CRB Racing[/MENTION]
[MENTION=131738]rics97toy[/MENTION]
[MENTION=550950]jonesbt[/MENTION]
[MENTION=640803]964runnerlife[/MENTION]
[MENTION=596468]AlpineHigh[/MENTION]
[MENTION=34852]crazydubman[/MENTION]
[MENTION=644853]Kauai98[/MENTION]
[MENTION=650787]z_runner11[/MENTION]
[MENTION=460034]sogood[/MENTION]
[MENTION=647175]Gabino951[/MENTION]
[MENTION=451419]ylime[/MENTION]
[MENTION=215613]BlackPony[/MENTION]
[MENTION=650700]Jovaa[/MENTION]
[MENTION=651432]getnherwet[/MENTION]
[MENTION=653012]DGL02Yota[/MENTION]
[MENTION=653314]DinoM[/MENTION]
[MENTION=631239]DesertSessions[/MENTION]
[MENTION=657929]Leonarte1997[/MENTION]
Interested in a kit [email protected]
thanks. New to the thread but now seems more i read here the more i am not so convinced a good idea to switch over. Would love to have the e-brake back again more than anything else. Constantly gets frozen and i dont want to spend anymore time under there with antiseize and a torch...
I've been working on this project for a few years and finally had some time to get serious about it. The design is complete and fabrication is in progress.
Disc Brake Conversion Kit: $160
This is a bolt on kit to replace the rear drum brakes with disc brakes.
What's included:
- Conversion brackets & spacers (1 pair for 1 axle).
- All hardware to mount the bracket to the axle and the caliper to the bracket.
What's required:(details below)
- '94-'04 Mustang Cobra rear calipers & caliper mounting bracket.
- '94-'04 Mustang Cobra rear brake pads.
- 2003-present 4Runner rear rotors.
CAD Images:
The Brackets:
The brackets are laser cut from 3/8" A36 steel. The spacers are also laser cut from A36 steel to match the brackets. Both the brackets and spacers are Zinc Yellow-Chromate plated to prevent corrosion.
The brackets are designed to fit the factory 4Runner axle housing with ABS.
The spacers are required to get the proper offset for the caliper mounting bracket. They allow the rotor to fit properly in the caliper mounting bracket.
Parking Brake Kit: $180
I completely re-worked my junction bracket to increase the force applied to the caliper. Instead of using off the shelf parts that I used in the first version on my 4Runner, I designed new parts and had them fabricated to provide the best mechanical advantage in the space available. The junction bracket now incorporates a lever and pulley to increase the mechanical advantage over the 1:1 ratio of version 1. The 4Runner parking brake cable enters the junction bracket through the aluminum fitting in the front, loops around the pulley, and ends by securing to the zinc-yellow fitting.
The kit includes everything required to connect the parking brake in a way that I'm comfortable having my name associated with. Here's an example of what is included.
- (2) brake cables for the Mustang calipers.
- Factory clips to secure the cable on the caliper.
- Junction bracket for the cables.
- Fittings to adapt the factory cable to work with the junction bracket.
- All necessary hardware (all 18-8 stainless steel).
- Spare rivet nuts, just in case you need them. Or if you haven't used them before and need to experiment before installing on your 4Runner. The correct size drill bit for the rivet nuts is also included.
Brake Line Kit: $60
These brake lines replace all the brake lines on the rear axle. The copper-nickel lines replace the hard lines from the axle mounted "T" to the outside of the axle. They mount using the factory tabs. The stainless steel braided flex lines connect the copper-nickel hard lines to the caliper.
The year must be specified for the brake line kit due to the changes in the ABS system. There are two different sets of hard lines, one for '96-'00 and one for '01-'02.
Pre-Order:
1. powerman83 (parking brake kit also)
2. Blackdawg (parking brake kit also - Tacoma)
3. ACE115 (parking brake kit also)
4. itskmill06 (parking brake kit also)
5. Twitchstyle13 (parking brake kit also)
6. AntsyMo (parking brake kit also)
7. coleworld427 (Instagram)
8. Jaysen4runner (parking brake kit also)
9. Xjazzwreck11 (parking brake kit also)
10. kirkman (parking brake kit also)
11. Bdnewyork (parking brake kit also)
12. Mike Fulghum (parking brake kit also)
13. tytacoma89
14. CRB Racing
15. Pfeiffer124
16. rics97toy
17. jonesbt (parking brake kit also, '01 Tacoma)
18. pharcyde145 (parking brake kit also)
19. 964runnerlife (parking brake kit also)
*Bold text is confirmed parking brake kit*
Installation Instructions:
Click here.
*****These brackets have not been tested/approved by the DOT and are recommended for off-road use only*****
Is there any way we can get this. Or did you stop production? I’m trying to convert my 96 to rear disk and keep parking brake and abs
I realize there are a lot of comments on this thread, but the post above yours will start you on the path to answering your own question. It requires a wee bit of reading, but I bet you can manage it. If not, ask again and I’ll gladly dig this horse up from the grave and beat it to death again again again again again.
AndiGarage
