Rear end Rust/leak w Pics..
Your rear lower control arms are probably about to rust clean off of what remains of the frame, judging by the look of the rust on your rear diff alone.
I'm pretty sure you have a hole on the other side, Looking at the pics and the way the wetness pattern flows downward with the peak almost pointing to the other spot. It's also above the other place of wetness, so it can't be the other hole. The first couple of pictures really shows where the hole is on the left (from the back)
Yeah you might be right. When I do that side I'll have to look real close. It might be really small cause it isn't dripping anymore since I have put the temporary putty over the hole on the right side. Hopefully I'll find it when I do the left side! Thanks!
It looks to be above the fill hole so it may not be apparent until you refill with oil and drive it around the block. (unless you can spot it) That's the way my two holes were.
