Rear hatch problems
Tailgate Latch & Switch Not Working
I replaced both the latch and the switch in my 2006 and it still wouldn't after initially replacing them. The latch died first, but the switch still activated the motor inside the latch. Then my battery and alternator went, so I went a couple weeks before replacing the latch and switch. Disconnecting the battery for a few minutes then letting it sit for an hour or so got it to work!
I recently installed a rear camera and new radio/navigation. I did unplug the connector to the latch motor to access behind the ECU to route cables but after re-plugging it in the rear door would no longer open without the manual release inside. The window still functions but i have yet to test the wiper and the wiper fluid.
Also there is no sound coming from the door when the button is pressed (i.e. no motor trying to open or close when it is lowered). I wonder if I severed a wire somewhere while trying to get the camera wire up the door side to the grommet?
After you finished the work does your wiper work correctly and does the window work correctly using the key in the hatch?
You could try and do the window reset by using the dash switch, roll the window all the way down and then roll it all the way up holding the switch in the up position and continue holding a few seconds after it's all the way up, I know with you disconnect the battery you have to do this to get all the functions to work incorrectly again so it would be the same if you bumped a connector and it temporary disconnected it, so it could also fix the hatch not working, if this doesn't work try doing the same for the driver's window, when I changed my battery just doing the driver's window made the rear work correctly again.
If none of the above work you most likely have a loose connection/plug.
I just fixed it, all i had to do was unplug the battery for 20-30 seconds then plug it back in. So I'm assuming all it was was that I needed to reset the rear ECU after unplugging the door motor.
Thank you for the quick reply and helpful info!
My issue is my latch handle stays compressed and will not open. I've tried spraying a generous amount of WD-40 on the latch handle hoping it would loosen up rust/dirt built up but no such luck.
I should also back up and mention i have issues with my power locks where the power locks do not work when using the inside button (no sounds at all when using the power lock button) and when using my key to lock/unlock all locks from the outside, it will only unlock the one door.
Any ideas where I go from here and/or how to get the tailgate open?
I hope by now you got your gate open. This thread problem was a different generation latch. Yours it totally mechanical. Like I said I hope you solved your problem already.
Had anyone with a rear latch problem ever heard of the ECU having a battery. I've got my latch working perfectly with the 4runner on. Once I turn off the the ignition the hatch will not work. If I turn the key on and cycle the rear window everything operates normally and continues to until I turn the ignition switch off. It's like the ECU does not remember the reset of cycling the window. Any ideas?
Rear hatch losing its memory!?
I’ve been having the same problem regarding the rear hatch, if I unplug the battery and plug it back in and “normalize” the rear window it works for a few mins then stops and the window must be unplugged.
I called a dealership and the guy was pretty helpful, he gave me the normalizing method used at that shop. (Unplug the battery for about 30 seconds which the hatched closed, window up, then plugging back in, rolling the back window down then back up, holding the up bottom for s few seconds, locking and unlocking the rear gate). He also told me if that doesn’t do it there is a Ecu or two that could be loosing memory... can anyone speak on this or give me some tips moving forward.
Did this get solved?
Same issue exactly. Was this solved? Is it a failing main battery, possibly? My voltage is low on my main and I think it might be causing this. Reads around 12.3...
Is there a way to manually open the hatch from the outside or disengage the locking mechanism entirely so the door will open from the outside? Plot twist: I have a small couch in the back and what are the odds that the actuator stops working the minute I put a couch in there.....
I can't think of way to manually open the tailgate from the outside if it is fully latched or half latched, and the latch motor won't engage. Definitely try removing the negative from the battery and try opening with the latch release button on the tailgate. It is possible to remove the large plastic panel on the inside of the tailgate with the tailgate closed. You will need to remove the bolt connected to the cloth handle and pull out all the clips, then slide it up. With the whole panel and vapor barrier removed you might be able to gain access to the release lever. You need to pull up on the second, smaller lever. With a couch in there that would difficult to do all that, but maybe not completely impossible.
I recently replaced the tailgate window regulator assembly and came across the issue with the door latch not working after putting everything together. Here is a summary of what I learned:
2008 Toyota 4Runner SR5 - Tailgate Repair and Overhaul Summary
2021-01-20
There is a lot going on in the tailgate of 4th generation 4runner. If you live in a winter wonderland it can become a rusty mess in there after a few years.
The space inside the tailgate is known to collect moisture and parts such as the door-latch and power-window regulator assemblies can rust and may fail in damp environments. The latch release button on the tailgate handle is reliable, but the black rubber cover is known to soften/melt in extremely hot weather and might need to be replaced. The latch release button is about $80. You might be able to find just the replacement rubber cover.
On my vehicle, a 2008 4Runner, the right window mount on the power window regulator (rail and cable) assembly rusted and broke-off. The regulator assembly needed to be replaced, while the glass and the power-window motor were removed and re-used. I was able to purchase an OEM rear window regulator assembly via eBay in the USA. The total cost was $250 CAD with shipping and duty and exchange rate ($150 US pre duty/shipping).
All 4th generation 4runners (2003-2009) have the same tailgate and use the same parts as far as I know.
Note that after completing work inside the tailgate, it is a good idea to make sure the tailgate drain holes are open, free of rusty debris or sand, and lubricate everything that looks rusty. A little copper/silver anti-seize on rusty bolts doesn’t hurt.
Most repair work inside the tailgate the involves removing the white connector between the latch and the ECU, typically to open the 5-bolt panel that the ECU in mounted on. It is likely that you will find (after reconnecting this white connector, putting everything together, reinstalling the plastic grey door panel and closing the door) that the door no longer draws in automatically and loosely half latch. The familiar sound of the latching motor is completely absent. At this point you will not be able to open the tailgate, lock your vehicle, or lower the rear window because the tailgate is not closed all the way. No worries. You will need to pop the hood and crawl inside the vehicle.
Reset the ECU:
You likely reconnected everything properly inside the tailgate assembly and you likely did not break a wire, because you were careful. The tailgate ECU does need to be reset. The ECU (electrical control unit) in the tailgate is tied into the vehicle’s overall security locking system. For some reason, if the white connector between the ECU and the latching unit is disconnected and reconnected, even for a few seconds, the door latching motor will no longer operate. To get it working again, disconnect the negative terminal on the battery, wait 30 seconds or so, and reconnect the negative battery terminal. If the door is half-latched, you will need to manually unlatch it from the inside and then push it back in to activate the latching motor. It should automatically draw and operate normally. If not, there could a problem with the latching unit itself, but unlikely if it worked before the overhaul. Despite the cheap feel of the momentary push button on the latching switch, it is more rugged that one might assume. It can be removed and easily tested with a continuity tester on a digital voltmeter. There is also a 10A fuse for the tailgate ECU in the engine compartment fuse called labelled ECU-B. Ensure this is not blown.
Unlatch the tailgate from the inside:
When the door latch motor fails to operate, you will need to manually unlatch the door using the door release lever inside the tailgate. If the tailgate is closed and half-latched, you will need to crawl inside the vehicle to do this.
The manual release for the door latch is accessible on the inside by removing the small grey plastic cover on the door panel. You will likely need to cut a hand-sized hole through the poly-tarp plastic sheet, remove the white plastic box covering the two levers on the left side by pulling up on it. You can reinstall the plastic box and tape up the hole after.
Reach deep into the hole and pull up on the second, smaller lever while pushing gently out on the tailgate. It should release and the door should open. If you have already reset the ECU by disconnecting/reconnecting the negative battery lead you should now be able to push the door closed and the latching motor should operate normally, drawing the door in.
You should now be able to lock and unlock all the doors via the key-fob and the drivers door.
Enable the “rear window down” key-fob button and normalize the rear window:
There is one more issue to address. Since disconnecting the battery negative you will find that you will no longer be able to lower the rear window using the key-fob. The truck will just beep at you. To fix this, insert the key into the ignition, turn it to the ON position, and lower the window using the dash rear window button. You might as well normalize the window at this point, as per the Toyota manual. Normalizing means running the window to its extremes and hold it there for a few seconds.
You should now be able to lower the window with the key-fob “rear window down” button and raise the window by inserting the key into the tailgate keyhole and turning it fully clockwise. Everything should work now, door latch, all locks, wiper, defog, and window up/down. Test them all.
TIP: Remember that you need to press the key-fob doors unlock button twice to unlock all doors including the rear door. A single press unlocks the driver’s door only.
I went through a similar issue over the weekend. I have 2004 4runner and the rear hatch wouldn't disengage from the lock. You could hear the motor sounds when you tried to open the door but wouldn't work. I bought the latch off Amazon for like $65 bucks. I replaced my old one. I ended up changing it and it seemed to have no power to the new latch. I pulled the blue plug in the rear hatch door for probably 5 minutes then started the 4runner again, then used the defrost, back window and locked/unlocked all the doors and it finally started working like normal. There was def some type of reset for me but I'm unsure what exactly did it.
4th Gen 2007 4runner Sport; intermittent fault where the release button worked, actuator / motor worked but then suddenly nothing. I could hear the motor sometimes run but wouldn't lock or unlock the door. I could only close the hatch to catch on the first lock but couldn't get the door to pull closed like it normally would.
Over a few days and after hours of reading 4th Gen Forums and watching YouTube videos I finally came across this YouTube video which was the exact fix I needed. The video: short, sweet, direct to the point and best of all didn't cost a dime!!!
Hopefully this link to the video will work:
Toyota 4Runner rear hatch repair - YouTube
What did you end up doing? I made a stupid mistake today and may be in the same boat as you were.
https://www.toyota-4runner.org/3785511-post8.html
I have repaired 2 4runners with hatch issues and both were the latch. One of them completely quit and the other was an intermitten problem. Both of them had rust and corrosion on the latch which leads me to believe they are prone to water getting back there.
Sent from my SM-G998U using Tapatalk
AndiGarage
