Replacing bulbs in dome and map lights
Myriad_Rocker
So...dumb question. I tried searching and I couldn't find anything. I'm sure it's out there. I may not be searching for the right thing.
I'm curious how the map lights and dome lights come apart to replace the bulbs. I tried pushing and pulling on them today. I didn't want to break anything so I didn't use much force or pry on them with anything.
I'm sure this is a stupid questions and the answer is easy.
Lol, indeed. If you look closely at them, you'll see divots in the clear plastic housings around the bulbs. Insert something small into the divot, and pry out. It doesn't take much and they're fairly resilient. They hinge on the side opposite the divot so once that side is out, you just pull the other side off. Installation is the reverse. Install the hinge side and then push the divot side back in.
Here: http://www.ebay.com/itm/10-x-Pink-L...sories&fits=Model:4Runner&hash=item3f12b415cf
Videos in the ad.
