*Review* Alpharex Pro headlights
That’s a bummer. Guess I’ll have to keep playing with em. I do wish it was an actual plug n play.
Your best bet for stalk controlled DRLs is to hijack the DRL wire. I think the harness is in the fuse box. I can do some more looking into it. I think the antiflicker adapters for LEDs on other makes of vehicles would work. I have some of those laying around. If I can get the male and female connectors I'll give it a go.
I have the Luxx's so not exactly the same but similar. High beams will still be DRL unless you clip the wire that supplies the lower voltage on the wiring harness from the vehicle. Not sure why they did that. Seems like it could have been powering the new DRL strip instead. As for the Alpharex DRL, you have a fuse tap on the INJ fuse?
Sheesh that sucks. Let me know if you figure it out.
TRDJon did a review on the alpharex Luxx series headlights heres some links
ALPHAREX Luxx Series Install and First Impressions - Toyota 4Runner
YouTube
Alpharex Luxx Series Night Drive Only - Toyota 4Runner
YouTube
Update: June 29, 2020
I put my stock headlights back in. The alpharex pros with HIDs are a huge improvement over stock, but they are too bright for my eyes.
The projectors need a foreground limiter. The intense foreground lighting dialates the pupils too much and makes everything farther out and to the sides too dark even though the lights are brighter than stock.
I can see why morimoto designed their lights with a dark spot in the front of the vehicle now.
I'm going to store these til I have the ambition to take them apart and tinker with adding foreground limiters.
Having driven with the stock headlights for a bit now, I realize my eyes are not as strained anymore after a long night drive.
The stock 4runner projectors are actually not that bad. They have a good foreground limiter, they don't blind drivers to your right when you are passing, but they do need higher output. Old tech but saves your night vision.
I can see why the best HID projectors have foreground limiters now (TL HID projectors, rx350, etc.)
Thanks for keeping us updated.
For those who run PRO with HID. Can you fit the HID H11 bulb into pro series? The documentation says they take h7 bulbs only.
Anyone else have the alpharex luxx in alpha black? How is the light output compared to stock with maybe some LED's in there? The only review I can find is the TRD JON one.
I contacted Alpharex and they said these LUXX lights have 1800 lumens. Seems kinda low when you compare to the 5000 lumens that Lasfit claims for their 4runner specific bulbs for the stock headlights.
I have the black pro series...the output is like night and day, I remember my first night driving the 4Runner home with stock lighting. I kept checking to see if I had actually turned the lights on. Poorest lighting I've seen and on a 2019? Unacceptable. Alpharex was worth every penny...I replaced the fogs with Baja sae and they are insane. While I have spent about $1100 on lighting, I am very happy!
anyone have a recommendation for h7 leds? I'm running anzos now with amazon LEDs and the light output in meh. the Alpharex pros look closer to stock so I'm switching over however I want LED/ HIDs.
I was supersized when I used LED's in my anzo's and the beam pattern didn't change. I was always under the impression that LED's in a halogen projector would have this issue, but clearly not the case. I ran hid's in my stock headlights do the verry same reason but didn't want to drill the dust cover again. I plan to not drill the dust covers on the alpha's either.
xd does have h7 leds, however they are listed as not street legal... so maybe I'd try them as high beams only provided i can fit the box in the light enclosure.
Yes. I thought the same thing on the 4runner head lights. Absolutely terrible. I bought a used 2017 and my 1998 Durango that the 4runner replaced had better lighting in the headlights. :-|
With the PRO lights, what bulbs did you buy? Or did they come with halogens and you are referring to them? The LUXX series come with LED's installed already. If I went with the black pro series as well I think I still want to put in some LED's just to have the nice crisp white light.
I’m in the middle of installing some pro’s on my 4 runner. Have the bumper off and can’t seem to get the plugs lined back up to install the new lights. I took the Halogens out and wanted to run LEDs in high / low - do I need to order h7 to h11 adapters or something else specific? I have 2 plugs from the halogens I took out of the stock alpharex - are you guys wiring those into your h11 plug?
Thanks for any help! I can send some pics too if that helps.
Also - what’s the yellow short cable go to? I couldn’t get it plugged into any of the OEM ones.
Looking at the directions to wire these up do most of you just wire directly to the battery? I'm putting in an auxiliary fuse box for my light bar, compressor, and rock lights. I like my wiring clean and simple in the engine bay. Anyone wires these up to an auxiliary fuse box for power? Seems odd that you need to do that for plug & play or is that just for the DRL feature?
Thank you.
This is why I bought the pros and swapped out alpharex bulbs. By the way, many amazon lights list the lumen output as the pair but do not say it so most 5000 or 6000 lumen bulbs on amazon are actually 2500 or 3000 per side.
ALPHAREX Pro Series Headlights on STEROIDS | LASFIT LED Swap | 2014-2021 4Runner Install & Discount! - YouTube
The other dirty little secret with most drop in LED bulb marketing is that the claimed output is actually a estimated output, not actual output. To get actual numbers, one would need some pretty sophisticated test / measurement equipment - which apparently these marketers don't have. And don't for a minute think the estimates are anywhere near real world measured numbers.
The other problem - particularly with eBay and Amazon vendors - is that even if the output numbers were real, all of that light doesn't go where it's supposed to when you slap LED bulbs into a housing designed for Halogens. A not insignificant portion of it goes right into oncoming driver's eyes (as glare) because the bulbs are designed / engineered so poorly.
PRWhite
