RIGID SR2 10" HyperSpot Mounted to C4 Fab Hood Scoop Kit
I am new to 4Runners and I am just starting to build mine up. I am very interested in this mod and will hopefully be ordering soon. Loving the look!
I'm currently attempting to install mine.
Is the method of installing from Rigid extremely frustrating? What am I missing? The "compression spacer" allows the supplied bolt to spin while attempting to tighten the bolt…
How is anyone suppose to install the brackets into these lights?
My SR2 arrived today and I have the same issue. One end will tighten up with no problem. The other end just spins. Apparently there is a design flaw because one end of the casting will keep the bolt from spinning, whereas the other will not. I'll figure out how to fix it later when I have more time.
Yup, thats the issue I had and it was on both ends. But ended up getting it on just fine. Good luck!
HiVel-JR - I am looking to do the same install with the SR2 10" rigid and this thread is super helpful, thanks.
Where did you get the FJ switch? I am a total novice on wiring, and want to make sure I have what I need, you don't by chance have a link to the switch you purchased do you?
Thanks!!
Thanks!!
Amazon
https://www.amazon.com/gp/product/B00DWVNBIC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
and this too.
https://www.amazon.com/Genuine-Toyo...rd_wg=tZW1I&psc=1&refRID=4BN5G0S46GFZEC4MDFE0
So I am pretty close to done on knocking this out today, but I ran into a snag. Instead of the red/blue/black wiring harness from rigid that OP had, I have 4, red/black from the battery and red/black from the light.
Can anyone offer some guidance on how these four wires should be connected to the OEM FJ switch?
all help is appreciated, Thanks!!
ian2328
