Saw these on eBay 4 1.25" Wheel Spacers for $120
excuse my absolute noobness
if I got these I could do the 231mm upgrade on my '00 T4R3 without having to upgrade my 3-spoke stockers?
Based on what I've read, these spacers should allow you to upgrade your brakes without rubbing. I didn't have to run a spacer, but I also didn't have the split spokes either. I'm sure an inch would allow enough clearance for them.
The lugs on the spacers almost seem longer then stock. They fit flush against the hub and look clean. I have a little bit of steering wheel wobble after installing them but that could be from my shenanigans in the mud before I did my BMC. Gonna balance the wheels tomorrow, hopefully it goes away.
I got mine in the mail but haven't been able to install yet. Give me until Tuesday!
Would you mind measuring the inside diameter the wheel side hub opening? I know the hub side ID and wheel side OD should be 106mm.
[MENTION=119069]Mjno87[/MENTION] [MENTION=90965]Pitbull410[/MENTION] at what ft/lb spec did you guys torque down the spacer lug nuts and wheel lug nuts to?
Wobble went away after balancing which I expected, so everythings cool now. Good spacers.
[MENTION=75868]Ed_C[/MENTION] I torqued mine to 90ft/lbs with red loctite so they won't go nowhere and the wheels to 120ft/lbs.
Curious why you would run the torque up to 120#?
Installed mine , got a few hundred miles on them, no problem. Fit and finish is perfect. No complaints. Would buy again.
did you have to grind or chop off the OEM lug bolts when using spacers? saying that anything 1.25" or smaller might need to cut it off.
bluelinepilot
