SEATS...Im not a fan, I want to replace them
If you extend the lumbar support forward it makes it less curvy but also firmer
Sent from my SM-G930V using Tapatalk
For what its worth, just to add options to this thread, and I apologize for being new to this forum but we had some customer mention it so we signed up.
For the 5th Gens we have solved all of the issues that have been referenced...at least for the driver side.
Took care of the airbag with our own airbag proxy. Took care of the factory seat heater switches by making custom plug-in harnesses (there are two because its splits at the seat heater amplifier). And for the passenger side we've solved the OCS system errors but we just need to finalize the design. At least for the driver side there is a little bit of seat dissection, you retain the fore-aft motor (no way around this) and you can then mount the scheel-mann seat of your choice.
We've even worked out the compatibility issue if your truck happens to have the seat memory function.
5th Gen 4Runner Mounting Kit- Driver Side | Tolerance STACK
Suppose some pics would help and tons more info here:
Upgrade Your 5th Gen Toyota 4Runner with the Tolerance Stack Mounting Kit
Deka
