Separation Anxiety
Really? That long? I was thinking of going with 4x 6" Rigids in the front, is there any considerations I need to take when ordering so they can put mounts?
Instead of going with four 6" Rigid LED bars, go with one 40" :) Gobi can make a custom bracket for it.
However, if you're set on the four 6" bars, you can ask Gobi to customize brackets for those as well.
Hey brother,
I've got a gobi stealth and Rigids I bought while out here in Afghaniland. Keep in mind, the edge of the rack will dip down lower and run into the lights. I have 2 6" Rigid SRs on the outside and a 10" SR in the middle. I had to bring the 6" lights forward in order for them to clear the roof rack. Now granted, you can have Gobi modify the rack for a 40" SR (or so I've seen)
Hope this helps. Semper Fi
Cool thanks for the heads up Rudy, There are so many options to look at. I've seen RiDEs rig and I think it looks sweet with the 40" SR, but I'm curious as to what the lighting spread would look like 40" SR vs 4x 6" SR vs 10"/2x 6".
Jaker if I had a measurement of the front it'd be easier to decide how to customize it. Another question is: if I were to have a local fabrication shop make the mounts, would that do anything to the warranty of the rack?
