Shift Knob Bushings?
knbiker
Hi:
I have a 1999 4Runner Limited and a 2000 Wild 4Runner. Both 4runners are 2WD.
I would like to know which of these two shift knob bushings (for Auto Tranny) are using in the 3rd Gen 4runner. The Toyota part numers are
33501G or 90385-11003.
How many bushings need for each 4Runner? 2 or 4 bushings??
Thanks for your comments.
Regards
KNBIKER
Its DEFINITELY been done. I think it was in a build thread.
Did you search? I can't post the link now since I'm at work but you can use the link in my signature to easily find it.
I found the 2 options mentioned in my original message. I'm cnfused in wich is the correct bushing for my 4RUNNER.
The first number is NOT a part number. It is an illustration label number. It is used to look up the part number from the part diagram. They both refer to the same bushing but 90385-11003 is the part number. You need two of them:
From the diagram, you look up the part number:
Excellent!!!!!!
Thanks for the correction, information and picture.
Regards
KNBIKER
This is a pretty easy fix. Head to your Toyota dealership to pick them up. They had them in stock when I did this. Be careful not to pinch it when installing. Also, take the opportunity to be sure your link arm that connect to the transmission from the bottom of the shift knob is tight to prevent forward to rear play. Don't take up too much slack though. My wife loved it when I fixed this. The rattle drove her crazy.....er.
Also, you need two...not 4..
Check my build thread. I did it and took pictures.
I used 4 bushings as there were two linkage points with a bushing on each side.
Great information, thanks.
KNBIKER
