Shovel and Axe Quick Fist Mounts on Gobi Stealth Rack
414Runner
EDITED: It appears I cannot share photos via Google Photos, so I tried via Photobucket. Please let me know if you can or cannot see these. Thanks!
Today I got around to making a shovel and axe mount for the Gobi Stealth rack today using a couple sets of Quick Fists and conduit hangers. I haven't seen this particular project written up with photos/detail (correct me if I missed it), so I thought I would dabble with my first write-up. Let me know what you think/like/hate/or suggest.
Here is the finished project; I'll detail the specific steps I took after:
I got 2 sets of Quick Fist attachments, conduit hanger and the necessary hardware together. I went with 1" conduit hanger, but could've gone with 3/4". I also got a strip of sheet rubber to snug and dampen the hangers on the Gobi rack:
I super glued the rubber to the inside of the conduit hangers and gave them a test fit on the Gobi rack, which also helped cure the super glue:
Here's a close up of a completed piece:
And all 4, post rattle can treatment:
I finalized the location and secured the conduit hangers to the Gobi Stealth rails.
I put the shovel on the rear passenger side:
And the axe across the rear of the rack, which still allows for the hatch to be opened without interference:
Overhead view:
The overall project turned out pretty well. The rubber inside of the conduit hanger gives enough play to mitigate bumps while driving, but keep the Quick Fists secure. Like I mentioned above, I think 3/4" would've been a better fit and should the 1" start rotating down with time and travel, I will change them out. For now they are very snug. I am doing a 150 mile trip this coming weekend and will see how they hold up.
All in all, I'm less than $40 in on this project, which includes the shovel. Can't beat that with how much some of these accessories can cost.
Let me know what you guys think! Thanks for checking this out.
Hmm, I used Google Photos' shareable link to post them. Anyone have an idea why they show up on my end but not for you guys?
I'll try to get it fixed this afternoon.
Looks simple and functional. Thanks for taking the time to post your write-up. I did something similar for those who want other ideas. If interested, I can do a more formal write-up so this becomes a consolidated thread.
This is one of two mounts I made to carry both the shovel and axe on the same mount. I used the same QuickFists and Cruizer LED Off-road Light Bar Clamps.
I am now doing a longer version to hold my TredPro boards.
I like yours alot. Definitely more robust than what I did and I like the idea of mounting them in the same location. Is the lower portion of that mount also a Quick Fist product or is it a plumbing/electrical product?
If mine starts to show signs of weakness I'll definitely mimic your setup.
It's a clamp for light bars. I embedded a link to the product sold on Amazon in my post. It does slip a bit even when tightened all the way down. I am going to add a layer of grip tape on my rack so the rubber has something thicker and less smooth to grip on to.
I also used the same light-bar clamps linked above, in combination with the Quick-Fists for my shovel mount, on my stealth rack. The clamps are only $11, adjustable for a range of tube diameters, and solid.
How does nut to hold the QuickFist on the left not interfere with the light bar clamp? Got a pic from the other direction? TIA...
It's good to inspect the QuickFists. Mine suffered rubber fatigue after a couple years (the latching rubber flap was ripped off on a few of them). Easy replacement but something to watch out for in time.
Great mounts though!
Sent from my Pixel 2 using Tapatalk
Posting in this thread bc I can’t start a new one. Besides the Gobi tie downs, what is everybody’s favorite method to tie down boxes/bags on their Gobi? What about hard mounting boxes?
Here's my version. Same basic idea but with a few minor differences.
I had the machine shop at work waterjet two 1"x6" plates from 1/4" aluminum. Instead of tapping the light bar clamp I just added an extra hole for the 2nd QuickFist and offset them from the bar clamp. I also used 1/4" SS bolts vs #10 to secure the QuickFists. To prevent the clamps from spinning on the rack I just wrapped two pieces of cloth bicycle rim tape. Overall it seems to work pretty well. Thanks again [MENTION=128325]cutty01[/MENTION] for the idea.
Crookedcat
