Show me what you have done with the factory TRD Pro roof rack.
Plano boxes for recovery storage and with DIY led roof rack set up.
I've always liked the trd roof rack. It will match well with a tube front bumper bull bar and a tube rear ladder.
Hi Would you share which mounts and which Plano boxes you used in your set up. This is exactly what I am trying to do .
Thanks in advance.
Added a Cannon. ARB 2500 on the small rack, pushing the limits. Torx lb hasn't changed/moved. Ended up using the BajaRack BR-AWNMNT-TYOEM-2-0
and getting the ARB ARB Quick Release Awning Bracket Kit - ARB - 813409
Which Plano boxes are those? I have a trunk, but it sticks up pretty high. Fits all my camping stuff. My recovery gear is in the back. Would love to put the gear up top with a slimmer box and put the camping stuff inside.
I custom machined a tube that replaces the plastic piece at the rear of the rack.
I also machined some custom caps for the front mount where the top rail used to reside.
I have produced a few kits and I am thinking of selling them if there is enough interest.
PM me if you are interested.
YES - Just PMed you
.mc
Thanks in advance.
PLA11842 part number for the Plano box. It's a 42inch PLANO gun case with key locks on the latches. The box is mounted on T-slot rails that are cut to length to fit on the trd roof rack.
This is the full name of the rails, TUNTROL OE Style Crossbars Roof Rack Replacement Fit for Toyota 4Runner 2010-2021 Aluminum Luggage Cargo Carrier,Black.
You can find both items on Amazon.
Ill show better photos of the roof rack this weekend.
Take care
Part# PLA11842
42 inch PLANO gun case
Yes I agree. I hate bringing in dirty recovery gear inside the cab so I resort to keeping all the recovery gear outside or on the rack.
I've had this plano box for a year on my rack. I haven't seen any discolor due to fading. And this 4R is my daily till I get my MR2 running again lol.
Take care
Take care
Thank you so much.
Love the cargo case setup - what are those?
Hey [MENTION=711925]JAYR4R[/MENTION], love that setup, thanks for providing. I am looking for cargo cases exactly like that to put on top of the TRD pro roof rack.
But I cannot figure out what cases and what mounting brackets I need that configure with the TRD pro roof rack.
Mind sharing what cargo cases you got as well as what mounting bracket you used?
TY!
TY!
Hi [MENTION=756621]Unexpectedoffroad[/MENTION]
You can buy these parts on amazon
PLA11842 PLANO Box
The most important part is the TUNTROL roof rack bars. They are T-Slot rails that allow you to use t-bolts for different accessories. It takes a little bit of modification to make it work. You'll need to cut them to size to fit all the way across and reuse the TRD rail brackets. Then mark and drill a hole on each end to install a screw rivet for the star knob. That's about it.
Here are some pics hope it helps
I throw on my Maxtrax Xtreme boards and Diode Dynamics 42 inch light bar on when expecting to go where I may need them.
Smaller mounts by the base of the rack is for scene lighting which I run a pair of Selective Yellow Diode Dynamic SS3 Pro's with a clear flood lens for scene lighting.
GZila 1.75 tube mounts and KC Hilites mount for the light bar.
Those lower mounts what are they and where did you get em? Thanks
What gzilla mounts are those just curiously?
stc6306
