AZ Silver Dollar
Never mind I dont even have a space for it....
The Lasfits are REALLY bright, they're actually the same Lumen rating as these Meso pods
Yes, very good advice. As with so many other clipped-in pieces inside and outside the 4R, if you know where to grab and pull, and you go slow and deliberately you will be OK. But the first time attempt is kind of nerve wracking, with all the noise of clips releasing.
What I found daunting was the idea of pulling off the mirror. I didn’t trust myself to not break something. I was more comfortable with the painted cover removal method. I’ve used this method four times with no problems. (The main grab point to start is the pointy section toward the window). It gets easier each time. See post 20 below for more info.
2014 Side Mirror Bulb Access
Either way, you will be successful.
Where did you get the t10 lasfit...thinking about not doing meso and maybe just doing lasfit ledI've done both FyreFlyz LED bulbs
And Lasfit LED T10 bulbs, highly recommend the Lasfit bulbs, they're bright as hell
Pretty much any wedge bulb will fit
Sent from my ONEPLUS A6013 using Tapatalk
I want these for my Pro!!! :shrug:
And here is a side by side before and after, the new Meso on the right, and the Lasfit on the left
Further back
These two pics sold me .. thanks
