"Snowball" Build Thread
What width did you go w/ on the F5's?
I went with the -10mm offset. Those in conjunction with my 1.25" Spidertraxx and I only have rubbing against the body mount at full turn in reverse.
Man! looks great, I am wishing I went up a size with the 255/80's instead of the 255/75's.
I'm sure you appreciate getting marginally better MPGs, though!
Good to see another Knoxvillian with a modded 4th gen. Im on the north end near the clinton hwy/merchants area. All stock at the moment. Got a 3" lift, JBAs, and 255/75/17 to go on here very soon.
Where did you happen to find that power block?
I think you'll be very happy with that set up. I don't live in Knoxville anymore, but I still visit around the holidays. Miss that place! If you're referencing the fuse block, it's made by Blue Sea Systems and you can find them on Amazon. The battery I bought through a groupbuy here on the forums.
Most recent update:
Installed "new" CV axles from CVJ. Running flawless so far!
Also installed new Moog LBJs. Also flawless, and greaseable. If you ever want to try this, I recommend having at least a four foot cheat bar...
The Christmas season has given me a lot more down time, so I've been able to get a few projects done.
1) Finally installed an adjustable panhard from Sonoran Steel. Fits like a glove and clearly helped re-center my axle.
2) A few weeks ago, I sprayed a debugging solution on the front of my 4R before cleaning it and it took the Spar Urethane clear coat off my headlights. They looked hideous, so I took this time to refinish them.
3) I decided that the lightbar sticking out of my lower grill was a little too tacky (girlfriend was kind enough to keep reminding me..). So I decided to adjust it further back on its mounts behind my bumper, and I replaced the lower grill that I had trimmed with a new one. Now it sits nice and hidden behind my grill until I unleash it :thumb3:
Note: If you've paid any attention to my previous posts, you'll be able to tell that the lower, middle portion of my bumper is no longer black. Well, the Plastidip finally started to fade and was chipping away from rocks flinging up on the road. Eventually, I'm gonna coat that area again but probably with some kind of semi textured bed liner. Thoughts?
Auxiliary lighting - check. Rigid 8" diffused rear lights and SR-Q diffused side/camping lights. Lights output it excellent. Almost too good..
tuṣṭāva
