Solenoid problems need help???
sedhed69
So basically someone was driving my 4runner while I was on the phone n it got ran off the road n went through a ditch at like 35 or 40 both tires hit front n rear n hit really hard..the engine light instantly came on n I got in the driver seat n put it n drive n pressed the gas n it reved up but didnt move.. same thing happend wen I shfited down to second but wen I put it in low it went n had alot of torque shifted up to second n then in drive.i have to manually shift in order to drive it.. so I got home put it on the computer n al 3 solenoids are out but its popped up electrical.. so I took it to a shop n the supposibly replaced the solenoids n nothing changed.. trans fluid is good n everything els?e.. could it be my wiring harness?? dont kno wat to do...?
Seriously man that is just laziness. Edit that post so it makes sense and maybe someone can help you out once we understand what the issue is. Normally I don't post about this sh!t but come on...
:welcome:
Replace the blinker fluid and the headlight bearings . If that doesn't help, it's definitely your flux capacitor.
fhgy0045
