SouthernSS
Here's a couple bad pictures. One of the tape and one of the cross bars. The cross bars sit above the side rail when pushed down as far as they will go.
Just wanted to let you know we got your email and it does look like the material shifted during the laser cut. We're going to get another side rail sent out to you as that appears to be the only fix. Check your email tonight or tomorrow with the full resolution.
I have a different problem that I try to solve. The last rear cross bar mounting holes are offset
The shark fin antenna is in the way
Ok, so i went out and installed some cross bars on our 4runner mule and I believe you just need to simply loosen the bolts for the entire roof rack and scoot it back a tad. There should be enough wiggle room to do this. I included some pics to show you what kind of distances you should be seeing.
