I set mine about an inch before I got resistance, used my hood prop tool to hold it open,,,the upper hoses hose clamp made for a great center point to the hood latch so both sides open at the same time,,I used stainless rivnuts and allen head bolts in 5mm instead of the pop rivets for the hood mounts,,,sits flush and tight.,,the relay on the passenger side I kept in place with the pivot supplied and drilled a hole in it's bracket to hold the washer hose...looks perfect...I also drilled a small hole next to the prop rod spot in the hood and hooked a lanyard to it so I have something to grab when I close the hood.,,it's just a standard key ring type....I'd post pics of it but I don't know how yet!! Really like this kit and appreciate leon for putting this together,,,,works great.,,thanks for all your help getting my account setup....oh and I didn't realize there was directions in the box...forgot to look.,,didn't need them as it's an easy install.
