Steel City Racing: King of the Hammers 2019 Toyota 4Runner IFS 4600 Build Thread
Yep. We could put one in the NorCal forum as well, ya know, for us NorCal'ers that would make the trip. ::biggrin2:
Figured I'd just tag you in the So Cal one, but you have a point, hahah. You can handle the NorCal, I'll handle the SoCal, and we'll coordinate between the two of us. From what I hear it's pretty much open camping in JV so shouldn't be a problem for a large group of us to be able to set up somewhere.
Well tag me anyway. I tend to miss events and dates a lot! I may not see when the dates have been set, even with notifications. I'm internet/social media inept sometimes. HAHA
Now...back to his build!
Are you not mounting the seats to the cage? Usually that's ideal so there's no way the seats can get away from the cage since that's your lifeline. And if you're not mounting it to the cage, are you doing the fabrication yourself to mount the seats straight to the chassis?
JV is a total free for all where you want to go. It hosts 50k people for KOH, I'm sure you'll find a big enough area to camp lol
Yeah, not too worried about space, haha. Funny thing is I'm out in Joshua Tree all the time, but I just haven't made the trek out to JV.
We're excited to announce that Cooper Tire and KMC Wheels have signed up to sponsor this King of the Hammers build.
We'll be running 315/70R17 Cooper Discoverer STT Pros:
DiscovererSTTPro_full.png.aspx
These will be mounted on 17" KMC XD222 Enduro Beadlock Wheels:
With Cooper and KMC on board, our sponsorship for KOH 2019 is officially full. We'll have more to show on the tires and wheels, and from our other sponsors over the coming months.
I have those exact wheels and same size tires. Be sure to get the 0 offset 17x8 wheels or they will not work. By "will not work" I mean that you will not be able to do anything to keep them from rubbing. No amount of cutting will help you as the tires will hit the front frame. You still have to cut the body mount and get a body lift to eliminate rubbing and pound some offending metal near the door jamb flat.
IFS long travel has quite a few benefits, I don't think he'll have a problem clearing the tires.
Just Curious - why would the Pioneer head unit be wired into the harness in the back near the factory JBL sub?
Saw it while tearing out the cargo area and had to ask.
I’m going to try and keep the head unit as I can turn camera view on full time, which may come in handy for a camera on the front bumper when we’re strapped in and can’t see over the hood.
They bypassed the stock amp
LONG travel or MID travel? If the tire is not completely outside of the body it will rub on the door jamb area. There is no way to stop this unless the entire front of the truck is altered. Too far out of the fender area and the tires rub on the door jamb, too far in and they rub on the frame. I want to see someone with a 4th gen with long travel and no rubbing who did not remove the entire front of the truck... show me one.
Long travel not stock length "mid travel". Hes getting +3.5 I assume. I know at least some LT kits move the spindle forward an inch, and he'll have fiberglass fenders. He won't rub on the frame and if he does he can easily limit his steering a hair, not a problem.
Do you mean the firewall area when you say door jamb?
I'd be down for that.
I'll start another thread in the So Cal section when there's dates as I'm sure there will be others that would make the trip. I've never been to JV but I know there's some awesome crawling to be done out there in the Cougar Buttes area that I really want to check out this winter. Didn't get the chance this past winter/spring due to rig and medical issues and preplanned trips.
The team and I would love to have you all out there. I'll keep you posted on the dates. And we'll be praying it doesn't break in the first 10-mins of the first run :)
Yes, the mounts will be integrated into the cage when it is built. The tie into the frame is required by KOH rules and the cage is the best way to do this.
"3) All seats must be securely mounted to frame of vehicle and mounts must be properly reinforced to keep seat from moving in relationship to the frame.
4) Adjustable track-type seat mounts must be securely mounted to frame of vehicle to allow no lateral or vertical movement between seat and frame or mounting track and frame."
A friend of Wyatt Scott - owner of RockSolidToys - will likely be doing the cage for us at the very end.
This ^^^ 3.5" exactly. Spindle will be moved forward. Fiberglass fenders.
Anyone: What is the OEM resistance range on our stock sender? I think it’s a high OHMs at F and a low OHMs at E right?
Going to try and get an aftermarket fuel cell sender that will work with my stock fuel gauge.
Question: For the Doug Thorley Headers, I want to keep catalytic converters. Are most keeping the stock cats or are they upgrading to high-flow cats (like Magnaflow)?
Quick update:
- First, I was wrong! I installed the ABS Kill Switch and drove all this past week - I thought the 4.7L was fast before. With ABS off, it's a whole new beast.
You all were right! We will be running KOH with ABS Off. I still like the switch so I can have ABS on when I drive to CA in mid-Sept, but once it's in CA, it'll be off full time!
- Salvage parts have started to arrive and the remainder should be here this week (Liftgate will be gutted - glass, motors, electrical, etc will be sold):
- PRP seats are here. These will be installed on temp brackets as soon as this weekend for the drive to CA and integrated into the roll-cage in CA:
- Fuel cell, mount, filler, pump, filters, Alltech baffles etc will all be here this week and I hope to have rough mounting done this coming weekend. Only thing I lack here is the AN fittings and hoses.
- Master Kill Switch from Painless should also be here this week and installed this coming weekend.
- URD MAF Calibrator will be here on Friday and will be installed this coming weekend along with gauges.
- Cooper STT Pros and KMC Enduro Beadlock wheels have all been received and are stored at Marlin Crawler's shops in CA. I'll hopefully have some pics to post soon.
More to come soon!
lindwlson982
