Charles4x4
Thanks - you certainly know your stuff.Well, looks like your getting lots of play on all the other forums too!! As well as the standard beating on Pirate!! It used to be really rough in the old days, now its even tame there
Pretty damn sure RST will pull thru, they are putting out some top shelf builds for the Toyota crowd lately.cant wait to see her all stripped down!!
To me- It all comes down to the front end!
Long travel with coilovers naturally! Id run 3.0 coils if it were me.
LSK and Solomotorsports make some wildly impressive kits built for racing
That IFS front carrier, standard Toyota 8"? sticking with an OEM Toyota version or going to do it right?
Id love to see a ProRock60IFS slipped under our Runner. Center Mounted of course
OR----- an IFS housing mated to a Toyota 10.5 that would be F'ing the Bomb!!
RCV IFS Yota axles do not have a popular following. There have been countless issues reported on vehicles running them with most guys even swapping back to OEM toyota CVs or OEM rebuilds by CVJ with chromo inners. (thats what im running now after easily popping my CVs with a front locker) Most reports are on FJCruisers.com and tacomaworld.com
SoloMotorsports even swaps out the Yota CVs for Dana's
Then theres that Toyota steering rack! replace that mofo!
Cant wait to see what you guys come up wither and how it survives getting used.
Document it all!!!! Pics and specs
Wyatt is a pro and the rear end is covered. But we've got just as much horsepower on the front. Steering and IFS will be stout.
Specifically hitting the diff, we cannot change the space we have up front per KOH 4600 rules. I originally was aiming for a Currie F9 or a D60 center, but both Wyatt and I confirmed there is no way it'll fit. So right now our plan is 4.56 gears (keep them big and strong) in the stock 8" clamshell, retain ATRAC, stout shafts, and a selectable ARB up front for worst case scenario.
And, I'm sure most of you have guessed by now - but we'll be running an Atlas II 4.7 case to give us low gearing even with the 4.56s in the rocks. Still working with Advance Adapters on the full specs, so hold tight on the T-Case for now.
Fortunately our core build team has a ton of experience with the stock Toyota 8" and thinks this setup will be strong enough for 35s running 2wd in the desert and 4wd with ATRAC and the rear locker in the hammers. I just have to be careful when I turn the front locker on vs. winching.
Most we have heard of have been breaking shafts on 40s or 42s vs. the actual gears. While we'll have shafts covered, we know the front diff will be the weak link, so we'll have to be smart.
More to come on the steering, IFS, and axle shafts. One hint here: The steering, IFS Suspension, and Axle Shafts are NOT available on the market today
