Stolen catalytic converter from 91, can I run a strait pipe and pass inspection?
Photojones13
Some rat cut out my catalytic converter, being that I live in Texas and the rig is more then 20 years old (1991),can I run a strait pipe and still pass inspection? Thanks.
Probably will need to check your local inspection laws, google is your friend there. As a point of reference, here in Utah you have to not have a check engine light (which you probably do, missing the downstream O2 sensor right?), you have to pass emissions (which you may fail without a cat), and there's also a visual check you have to pass.
This is divisive issue, but I feel like if the law says run a cat, run a cat. If you can legally drive without it, then it's up to you, but I wouldn't.
it's possible. a lot our vehicals burn clean enough that it will pass.
make sure your at operating temp before you go, and it don't hurt to "get on it" a little to clean out any extra carbon from the engine on the way there
I know you can't pass in oregon because we test all vehicles newer than '74. I know this varies a lot from state to state though. Good luck.
so in north dakota where we dont have any checks i could get rid of my cat on my 92 3.0 and not get a cel?
In most states, you have to pass emissions test and VISUAL inspection to make sure the stock equipment is still there and in decent shape.
Just go to a smog shop in your state and ask some questions before wasting your time and money on a test doomed to fail
If u have O2 sensors before and after the cat, no way will it pass, and it won't run great either.
patnewton
