Stolen spare tire....
I ordered two of the locks. One for me and one for my parents 4thgen. We will see how this works, i hope to have them by friday.
Brian
Solice said:
I was thinking that this thread or a shortened version (maybe one with different options for locks) should be made as a sticky. This is a pretty serious/important topic. I remember doing a search on spare tire a while ago and reading through a thread where a bunch of people were commenting that it would be next to impossible to steal the spare off of a 4th Gen. Unfortunately and at Krosno's expense we now know differently. Just an idea :) . Mods/Members what do you think?
I'll stick it for awhile.
bbumbles said:
Very good idea the only thing that makes me nervous is living in new england with SALT and have the lock rust after time and not being able to get my spare tire off when I get a flat. That is the only reason I have no ordered one yet unless I spray it often with WD40.
"Limited Lifetime Corrosion Warranty"
"Lubricate Grease Fitting Once A Year To Validate Limited Lifetime Corrosion Warranty DO NOT Use Lithium Base Lubricants"
It looks like it has a cover for the lock, and a grease fitting.
I'll post pics and details when I get mine. You also need to grease the spare tire carrier and winch yearly. They can rust and fail as well.
As I think I said, it is very tricky getting the thing just right. And I noticed over the weekend that the wheel is cocked just slightly, when looking at it from the rear. You have to stand back to notice. I played with it a little, but wasn't able to get it 100% straight.
I'll post a pix if I get a chance today.
I installed mine this afternoon and I didn't have a problem getting the spare to align straight. It fit back up there just perfectly. I didn't take any pictures but if you follow the instructions and drill the 3/8" hole you should be fine.
Terry, I took at look at the picture you posted and it appears you have it installed incorrectly. This most likely is the problem. The hole you should have put the bolt through needs to be drilled out.
Thanks! How did you come up with that? It sure wasn't in my directions! Also, how do you get access to the top of that cover where you drilled the hole - to tighted the nut?
No problem. The top of that cover actually has an opening towards the back for one to slip in a wrench or something similiar. it's tight but it definitely works to tighten the bolt. Once you do that make sure to align the bracket correctly. The holes need to be facing the rear of the truck.
yes i veiwed his other items on sale and it's quite suspicious.
check out what else he has:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33744&item=7966005240&rd=1
notice the "light marks" inside one of the spokes he mentioned. could it be he was in a hurry and scratched it with his tool? i know i may be jumping to conclusions, but you must admit....quite suspicious. looks like a tight squeeze between the spokes, and it's hard to get a scratch there in normal driving. if i were to take a guess......it belongs to your boss.
Man has that guy got the stuff or what!? If I buy your wheel, what would you give me for it? LOL I guess I never thought what a lucrative biz Ebay could be for criminals!
