chester4Run
Member
I'm working on the 2004 SR5 sunroof, trying to remove it because the sunroof frame is rotten (replacement inbound). I think there are four torx bolts holding the sunroof to the mechanism. I removed two plastic pieces from the sides of the sunroof that hide the mechanism, and there is another plastic trim like piece on each side covering the front torx bolt and partially covering the rear. I can't get this to pop free, and I'm trying not to break it. Has anybody removed this and have any tips? I haven't found a good video for the 4th gen sunroof removal (other than dropping the headliner and removing the whole mechanism which I'd like to avoid). This one is operating fine so I'd like to replace just the glass (and metal frame it comes in). Thanks in advance!
