Surprising my son with a 04 sport, offset question
Doc-Harley
I had daystar 2 1/2 x 2 lift installed and would like to have 285/70/17 cooper ST put on it before I give it to him. Would an aftermarket wheel with a different offset prevent the rubbing of the uca during normal road use? If so what offset would I look for. Thanks Dr.Shepherd
Nice gift :D
there is a lot of info here regarding tire sizing, use the search function and you will see a number of posts regarding fittment of 285's
Thanks for the replies, I have gone over this site many times and seem to end up more confused than I was to begin with. Once again thanks, I'll get it figured out.
I would go to the wheel/tire dealer and have them try the different combinations. It gets tricky because you may have one wheel that has less offset but is wider and that will negate any advantages of the offset. Hope this helps...
Adopt me.... ':awais:'
look for a wheel that has around 4.5" backspacing. In other words a 17x8 with offset between 0 and -25mm
If there is rubbing a set of wheel spacers can be added. There are different sizes ranging from 0.25" - 1.25"
Gonzaga Lobos
