Suspension Opinions please (detailed)?
jjdbike
Hey everyone.
I just picked up a ’11 4Runner SR5. I’m planning on doing some suspension work. My comparason is an 04 Xterra w/ HD shocks. As compared to that it’s too soft, too much body roll & break dive. I’d like tighter more percise control, a tad more ground clearance, and a litte more level wouldn’t hurt but it’s not a big priority. I’m not a bushwacker, rock crawler and even hard core off roader. It will spend most time as a commuter, some time bouncing across the dunes and on somtimes deeply rutted sugar sand beaches, occasionally drive cross country family vacas, and occasionally on dirt, gravel and rock trails.
I was set to get 4 Bilstein’s and a 1 1/2” spacer for rear. I heard from someone here who did just that and seemed happy. Apparnetly this is a common lift combo.
Then I called ToyTech.
Scott the customer rep from ToyTech suggested otherwise. He suggested the first thing I should do is replace the coil springs. He said that would maintain ride quiality while giving a little more height and allowing more travel. He suggested 521200 front 2 1/2” springs. He said the stocks had 500 lbs these have 620 lbs. He also suggested RCC 2” rear springs. Stock has 150 lbs & these have 190. He said the ’11 SR5 is 2” higher in the rear. This would lift rear 2” and 2 1/2 which would leave front end still 1 1/2 lower?
When I asked him about the springs vs shocks. He said using the stock springs w/ the extended 5100’s would put preload in the springs making the ride harsh.
RE: front tilt (rake) he (Scott fom ToyTec) said that the Toyota engineers had very good reasons for this tilt (e.g., so when rear is loaded the butt isn’t dragging w/ nose high, messing w/ MPG, breaking, steering, cornering etc.
I told him I was suprised that he suggested springs instead of 5100’s. He said at ’11 w/ 54K the shocks prolly stiil have some life. He siad that down road (like next year or so) I could go to 5100’s and they would give me an even better ride.
I’m thinking, at approx $100 an hour, disassembeleing, reassembeling and alignment. I don’t want to do that twice in a couple years if I can help it. He said if I can afford it that would be good and to also replace the bushings and washers. Parts for just the springs (no shocks) are $392. Combined springs, 4 5100 shocks, washers & bushings are $792. Don’t know how much labor that will be.
What do you guys think? Do you agree w/ Scott? Going cheaper... just springs? Going bigger shocks, springs & bushing?
Money is important (as in this will go on the credit card) so I don’t want to spend more than I must. On the otherhand I don’t wanna be penny wise & dollor foolish.
I greatly appreciate your input, opinions & suggestions.
Thanks much folks!
JD
read the stickies up top all the answers you seek are there. I run 5100s, stock coils up front and SAW 1.5 coils out back and LOVE the setup!
Assuming my finances fall back into line in the next year, this ^^^ is my planned setup. Once Sway-A-Way or whatever the new company name is starts production again.
Agreed with [MENTION=131488]ST1FLER[/MENTION]... I know you don't want to hear it, but there are HUNDREDS of threads on these topics... I know, I spent the better half of a year reading them. There are 20 different ways to skin this cat, and none of them are necessarily wrong. You just have to decide what you want to spend vs use it for vs positives/negatives.
I'm running 5100s all around with the front at 1.75 and one inch rear spacers on the rear... Stock springs. And yes, the ride is a bit stiff. But that's okay with me... I knew it going into this setup and I don't really feel it's ridiculously harsh. But that's me and my arse... Your arse might not like the ride/feel.
Read into the wee hours of the night... PM some guys who have the setup you are considering with similar year/trucks. They'll tell you what they think (good and bad). This forum throws a lot of shiote/digs all in good humor.... But most of these guys know 4Runners better than anyone I've come across in person.
And don't worry too much... no matter what you end up choosing, I think you'll find you'll be happy with it.
wasnt aware of that. I bought mine maybe 2 months ago from Wheelers
I had 5100's and spacers in rear. 1.75 front stock cool then 1" spaced rear. After lot of driving I found to soft and floaty specially highway. Yet alone loaded with Weight.
Now have 884 coils in front with 5100 on stock lowest setting. 1.5" SAW coils in rear. Very happy. Just firm enough to be firm and good on road. And hold 4 people w gear or bikes on rack without sagging hard and being to floaty. Great empty which is a lot of time. Yet flexy off-road. Very happy wish I did from start.
Same as you. DD vehicle and all around driver. Love little wheeling, I'm more deep woods and rocks though. Only once and while when I have time.
Thanks folks. Yes I have searched & read and posted, especially the “lift buyers guide. I posted this detailed thread here as ToyTec suggested a whole other route (i.e., way to skin this cat). As knowledgable as Scott sounded (& Toytec seems to be THE supplier), his info was different from what I’ve read here & even from ToyTec’s website.
I like firm, as long as I have good travel & control. My wife will hate harsh. I don’t have a lot to spend but want to be as confidant as I can I’m making the right choice as I plan on keeping this rig as longs as possible & want it to be safe, functional & durable.
JD
Thanks Moroney!
I was always under the impression that our stock shocks just aren't designed to be extended to accommodate larger springs, but toytec knows more than I do so the are probably correct. I however would replace the shocks if I were replacing the stock with longer springs. If you want firm, I read all the time about how firm the Old Man Emu lift kit is.
JD
I think what you are running into is that if you asked all the members here you would likely get about 100 different answers (other than search) about suspension. It's a very subjective thing and we aren't even getting into how tires could affect things. One persons perfect setup is too harsh for another, it's really a leap of faith if you have no experience or ability to ride in a truck with the setup you want. The bilsteins keep coming up because for the cost it is one of the most flexible options not just less expensive, if you didn't like the bilsteins with stock springs and a spacer, you can add SAW coils in the rear, still not enough? Swap the front coils as well to OME as some have done. If you get coils now your still buying shocks later no matter what, but if you get shocks now you may decide you never need different coils.
Bottom line is nothing I or any other member says is going to give you a definitive answer, or even the right answer for you. Gotta read many thoughts, opinions, and impressions and make your own decision.
Check out the guys who've gone with the 6112s out by Bilstien & totalautomotive vender here also ! Little more than 51s but a good buy without all other stuff . I also have 11 & went with 51s before they came out but had brand new 14 FJ springs put in & have never looked back !
My advice? Put the 5100's on it with stock springs. Many hundreds have done it and are very happy.if not then add springs.
So what I said but more to the point. I mean come on where are your charts and graphs to back that up Mr. 1ENGINEER...
:behindsofa:
... He said that would maintain ride quality ...
In another thread, you said this is what you don't want. Which is why I said I find the ride on 5100s with stock springs firm but not harsh. Is it perfect? No, but it's good. Hell, I'd have a full King setup if I had the budget. 5100s were the right compromise.
You're going nuts over this, just like someone did over tires a while ago. Time to make a decision and move on.
Thanks again everyone.
Yes I am going nuts over this Zach, you’re right. I’m OCD, I’ve got too much going on in my life & honestly it’s starting to stress me out. I’d put it on shelf for a while, try to relax for a couple months and then revistit in the spring w/ perhaps a little clearer head if I could. Truth is it really needs suspension work.
The parts price diff between just 5100’s and 5100’s & springs is $370. I don’t think it’s much if any more labor but I could be wrong.
I’ll let you know what I decide & how it works out.
Thanks again everyone. Your knowledge, expereinece and opinions ae truely appreciated!
JD
Hey [MENTION=131488]ST1FLER[/MENTION] I love your lift setup!
no, I think you are right, their site says :
AHA! I'm not crazy! Well, not too much.
Also keep in mind that IIRC the SAW's advertised 1.5" lift is on a 4Runner with 3rd-row seats. If you don't have that extra weight the lift will be closer to 2".
maybe a little taller. the 3rd row doesn't weigh that damn much lol
