Swap 2021 SR5 running boards
GrayFox7
Hey guys! Trying to figure out if I can swap out 2021 sr5 running boards on my 2010 sr5. It seems like I’ll have to remove the rocker panel to make it work. I feel like it won’t look right if I remove the rocker panels and then install. Any thoughts?
You mean you have a 2010 and you want to put in some rubbing boards from a 2021 on?
Yeah you’ll definitely have to replace the rocker panels on your 2010 to make it work.
Replacing with OEM SR5 rockers was over $500 in parts if I recall correctly. Or you can install the Schrockworks rockers.
