Takes longer to fill up with Gas than to remove your Sunroof
TRD 4RNR
Member
2 trim pieces and 4 nuts and the Sunroof popped right out. Made a small repair to the crack in the plastic trim with some silicone and fingers crossed this will slow the leak.
That's a sunglass case under the middle of the front of the Sunroof to provide a little flex and open the crack a bit. Jammed as much silicone into the crack with the end of toothpick. Then I built up a bead between the plastic and the glass 8" on each side of the crack. Letting it dry now - will pop it back in tomorrow.
alexhales578us
