Tech Help Needed: General Grabber ATX on 2018 TRDORP
Standard Load (P) or E load?
  • standard load (P)
    Votes: 7 53.8%
  • E load
    Votes: 6 46.2%
  • Total voters
    13
OP, the 285/70/17 fits just fine in the spare area. I have my KO2s in that size mounted up with no issues. It's a wider tire than stock so it hangs down a little lower, but it's not evident nor a hinderance, IMO.
P/SL vs E? For me, the decision was load C, which is the middle ground. Es are too much for the 4runner when it comes to street driving -- they will transmit small bumps and cracks in the road more than C and especially P-rated tires.
So consider other tires that come in C load in the size you want. To me, most AT tires are pretty close in how they perform given the same load rating comparison. The differences aren't that huge, I think. So, it comes down to the looks of the tire and load rating for most people. If I HAD to choose the between P and E, I'd probably go E. I don't daily drive much, so durability offroad would take priority. If I did drive a lot more, I'd probably stick with P and ensure my spare was well-maintained in case there was an issue on the trail.
This is how I ended up with Load C KO2s in 285/70 flavor. They look good and aren't too stiff, although they are stiffer than P/SL so you will feel more NVH with them.
I went with KO2s because of the 3 ply sidewall and being a C-load. The Generals are at a great price point, but I have had great experiences with KO2s and definitely would have been disappointed in going with the Generals for the $200 price difference. KO2s also look cooler because Smiles per Gallon is important :)
I'm pretty sure the C load KO2 has a 2-ply sidewall. The E load has a 3-ply sidewall for sure.
I have 285 E rated K02, ride seems fine to me but want to get C next time for less weight.
And as previously mentioned, 285(at least K02) fit fine in spare tire spot.
OP, the extra clearance is nice in Anza Borrego with 285 but I understand not wanting to lug around the extra weight/lower MPG.
wow, it is a lot tighter then I expected.It is flush against the trailer hitch. Maybe the chain pulley pulls it flush to it?
These are actually used 285 KO2 and K02 supposedly run small for 285.
They only sell stock size in SL (which they apparently don’t like being called “P”) and E.
Their website lists a C load range tire in stock size, I think? Not sure if I'm missing something.
A day or 2 off road by yourself? Definitely go with anything but P or SL. You're just asking for trouble with a P rated tire.
I went from stock 265P up to 275 E's and they are just fine.
Although I know they are heavier, so for the next set I buy will be 285 C range.
I can’t find that, and only see SL/E rating here.
https://generaltire.com/sites/default/files/tires/files/GT19_Grabber_ATx_ProductFlyer_v2_Print.pdf
I’ll be damned, I just found the C rated tire on TR. It must be brand new. Just bought SL in stock size 2 months ago, son of a *****!
You're right, General Tire does not list a C load on their website. If this is real, it'd be great. Guess I'll send another inquiry to General Tire.
the tire on that link has a load rating BELOW the load rating that General Tire gives for their SL tire... doesn't make a lot of sense...
Odd. Let me know if you hear from GT about why that's the case.
That said, I can confirm they do exist.
General Tire confirms that the 265/70R17 A/Tx does exist in a C load:
"We offer the Grabber A/Tx in an LT265/70R17 112/109T LRC, under part number 04509790000. We are currently experiencing a delay in site updates."
That said...
- The OEM tires are a 113S
- The A/Tx SL are 115T
- The A/Tx C are 112T
So the C are UNDER the original load rating for the vehicle (which I assume isn't good) and UNDER the load rating of the SL... which just flat out confuses me! I sent another question back to General Tire about that.
That said...
I believe that P-metric tires take a load reduction hit of 1/1.1, so roughly a 9% hit, when mounted on a truck or SUV. Also the LR C vs the SL would have different max pressures and would need to be run at different pressures for the same load.
That said...
They did tell me via email:
"Thank you for contacting Customer Relations at General Tire. You are correct, the LT C version of the A/Tx will be more durable than the P-Metric version."
....so hopefully the sidewall is a bit more durable? I notice that the tread width is ~1.2'' wider and the tread depth is 1/16'' deeper.
Got this back from General Tire:
"P-Metric tires are rated with a 10% overage in load capability when used on SUV's, Light Trucks, and Vans because of the difference in load handling. However, there is no 10% overage for LT tires. An SL tire has an equivalent 4 ply sidewall, while a C has a 6 ply sidewall, offering slightly more durability than the SL.
Part#: 04509790000
Pattern_Name: GRABBER A/TX
Description: LT265/70R17 112/109T FR GRABBER A/TX
Load Range: C
Load Index: 112 - 2469 lbs
Season: AS
UPC: 51342213313
Width: 10.43"
Rim Width: 17"
Secvtion Width: 10.7"
Overall Diameter: 31.61"
I asked a couple follow up questions and got this:
"The tire is 46 lbs. As for the load range E tires, they have an equivalent 10 ply rating."
That makes me particularly pissed that after ~30 days of hemming and hawing I bought SL-rated ATX's 3 months ago LOL.
I used stock size wildpeaks on my 2018. They have been great on and off road (though the off road stuff is pretty mild).
PRWhite
