Thank you bandi for the 5th gen ARB compressor mount
toppyjai
Evening all. I want to thank bandi, he's a fellow member on this forum that makes ARB compressor mounts. The mount is a simple 3 bolt install that goes into your engine bay. Here's pics of the mount for reference if anybody is interested. message bandi if you're interested to get the mount. I have the compressor wired to my SPOD.
Shown here mounted in the engine bay. It mounts on to the passenger side in the space above the airbox.
I wired the ARB compressor to the SPOD
I installed the SPOD switches by cutting into the eyeglass holder in the overhead panel.
looks awesome. Nothing better than a clean install. What did the compressor and mount run you?
What is the max PSI on that comp?
thank you for the compliments. The compressor is a ARB CKMA12, these aren't meant to fill air tanks. They're meant to keep a constant pressure available for air lockers. There's also no mention of duty cycle either if you were wondering, so don't figure you can operate them for very long, I'd say PSI would be 120. It takes about 2 minutes to inflate a 35 inch tire.
IMG_1145_zps4j5was8d.jpg~original
Loooks GREAT, nice clean install... I'm glad it worked out for you.... Thank You...
The base mount for a single/twin arb compressor is $100 plus $15 flat shipping... things go up from there depending on options required, adding ARB manifold mount, ARB 1 gallon tank mount, Viair 1 gallon tank mount....
