shootmymime
I can spin my bicycle.
I can also ride it with no handle bars. No handle bars. No handle bars.
A stock Honda Civic will chirp the tires when it's wet outside. Heck, my slug of a Pickup that put out about 130 RWHP chirped when it was wet![]()
Does the 7th piggy tap the maf circuit. That would be the first thing to check if that's the case.Not sure if this is related to the supercharger/urd 7th injector install, but I developed a few check engine codes.
After the initial crank after install, she purred like a kitten. No issues. Took it on a test drive, gradually easing into the throttle more and more. Just as I pulled back into the yard, it wouldn't stay idling. Pulled the throttle body and cleaned it as well as removed and cleaned the IAC. Idled now, but still low rpm and rough through rpm band when revving the engine or driving.
Plugged in the scanner, and got a code that said P0100 mass airflow sensor circuit.
Went to the stealership, bought new MAF and installed it. Idles perfect, and no problems driving now.
Now it throws 3 codes with CEL, P0100, P0101, and P0110. Mass airflow circuit, mass airflow sensor/performance, and airflow temperature sensor.
Any ideas what to get rid of these gremlins?
The comment was made about tires chirping when the ground is wet, which I have done in a completely stock Honda Civic. But that's not really saying much.
I've been looking into a replacement bolt for a while and have some leads, but nothing solid. It's ridiculous you can't buy just the bolts of brackets. I'll let you know if I come up with anything.
In regards to the lean, do you think your stock fuel pump is causing it? I always thought you needed a larger fuel pump to offset the extra fuel especially with the 2.2.
Ok supercharger guys here's my situation..
-SC'd with 7th injector,
-no fuel pump upgrade
-colder plugs installed
-170 stant thermostat
-Toyota red coolant
-smaller 4cyclinder tacoma radiator that low range sells(shouldn't be my issue)
-2.2 pulley
PART 1
I live at 6500 feet. I have never ever pushed the rpm gauge past 3600 rpm's. Up until the last few weeks, when climbing the mountian up the road my temps wouldn't get above 190 at 3,200 rpms going 70. Now they are getting higher than that at a much less grade. They do stabilize quickly when I get off the gas. When crawling in Moab they never got above 184 unless I started running the Ac...I was told by someone that I'm running to lean. At 3200 rpms and holding speed of 65 mph yesterday on same hill I'm getting 11.4-12.2 and a boost of no more than 5-6, engine temp of 212. I haven't seen boost any higher.
PART 2
Last year after running to Moab with [MENTION=44220]BigFishAllDay[/MENTION] and comparing notes I wanted to change to the 170 thermostat. As I don't have the premium working area for some things I chise to have the dealer do it. Fast forward 4 months and I meet with [MENTION=85218]Toyotacolin[/MENTION] and [MENTION=88391]NateMob[/MENTION] for a run in the hi country. I developed a radiator leak and contacted low range. At that point still dreaming of ifs I put in a tacoma 4cyclinder radiator. I notice that the thermostat housing is leaking from the DEALERS install. I proceed to try and remove the supercharger tensioner bracket to access the housing. Well I can't get the 10x1.25mmx77mm flat head bolt out. It's only supposed to be torqued to about 43 lbs I think. I try and try and call the dealer. They sent out the tech and he couldn't get it out either. At that point they say get a replacement bolt and we'll get it out and replace it.
That day has come that I need to get it out and they are proposing this. They suggest to weld a nut to the bolt and then use a larger wrench to bust it free. They also said I need to get a bolt which I didn't initially think to be a big deal. You all know it is a BIG deal. Two weeks ago I filed a complaint with Toyota headquarters and have been trying to get this sorted out with the dealer. They are complaining about having to buy a tensioner bracket kit for $260 just to get that bolt.
At the recent event I was at I talked to several toyota and lexus techs. All of them said that's crazy to weld there and it should be drilled and reverse threaded out. My local Toyota dealer is dodging me again like I'm going to forget about it.
Heres a mid to late 2014 water/meth article from fourwheeler.
1998 Toyota 4Runner - Meth Addict - 4-Wheel & Off-Road Magazine
