gamefreakgc
Elite Member
My rig: 1997 4runner Limited 3.4l 4x4
Just got a 7th Injector kit. I have the 1st gen gray top SC with the Fuel Management kit (FMU) from the dealer. I dont have the pressure regulator in the fuel rail anymore. Do I have to replace the Regulator in the rail and remove the FMU before installing the kit? Or can I just use the FMU as the regulator, and follow the directions and use the FMU as the regulator?
Also,
I replaced my engine recently. Previous motor blew the head gasket at 223k. I dropped a used one from a 2004 tacoma with 60k on it and put the SC on the replacement motor. The truck feels more sluggish now with the replacement motor than it did with the original motor. No engine lights, no codes, all plugs are put in the same as they were before. Any ideas why it would feel sluggish?
I can hear the SC whine, but It doesnt feel like it has the pickup like the old motor used to, feels almost as if its slightly suffocating to an extent. And it might all be in my head as well...but kind of feels like its the passenger side of the motor.
Re-check you vacuum lines. Depending on what accessories and intake you used, you might need to re-route the vacuum and boost lines. Probably has a boost leak. The vacuum routing for an 04 Tacoma is different than a 97 4Runner.
If you install the pump in the tank, that eliminates the need for the FMU. But if you don't have the stock regulator, you can keep it on there.
