Where is everyone buying replacement SC belts at? TIA
Thanks for the reply.
Can the Supra injectors be used with the URD 7th if I can't get it to behave with just the injectors? Or would I need to pull them off if I had to add the 7th?
The Super charger upgrade is solely for towing our camper so worried about high gear ping. I never WOT or pull high RPMs (I drive like an 80 year old most of the time) so high gear low RPM is my only real worry.
In your use case, I would recommend not going just with Supra injectors. From what you describe, you will only be using the engine in closed loop. Closed loop is when the oxygen sensor controls the fuel supply to keep it at a stoich 14.7 AFR which is what causes the high gear low RPM ping issue. It gets to hot and runs too much timing and pings. If you put only the Supra injectors in it will pull all that wonderful extra fuel that gets rid of the issue and instead keeps it exactly the same as your old 4Runner injectors, effectively making the upgrade null and void. Only at open loop (greater than 70% throttle) does it add the extra fuel.
The 7th injector kit instead has a piggyback controller that will override the oxygen sensor reading and add fuel in closed loop. It also allows you to pull timing in the 2000-2999 RPM range where the majority of pinging happens (once you hit 3K RPM the ECU takes an active role in pulling timing advance). This would be the best option. Now of course, you can still add the supercharger alone and see how it drives. If you are at any kind of elevation over 1000 feet, you may not have any ping at all.
As always Jerod, bingo.
OR!! He could just mash on it all the time teehee...
It’s funny how timid most of us seem to be. I’ve had mine SC’d for like 7 years or something and I’m just recently starting to be more aggressive with it and man, having a heavier foot REALLY opens them up Hahahah.
What inspired me was a coworker: he used to build monster Supra engines, the straight 6’s I forget the insignia. But anyway he claims to have had many that had upwards of like 800 horsepower or some insane amount and then ran HARD. Turbo charged I’m sure and all hopped up with fancy tuning.
Anyway, what I’m getting at is that it seems to be pretty safe to ride them a little hard after being properly warmed up and all that of course. These 3.4’s are pretty stout engines for what they are.
I have a '97 as well and I too had trouble figuring out the vacuum hose routing as it related to the power steering pump. Apparently, few of the 5vz-fe 4Runners had this arrangement.
See Figure G on page 22 of the guide 4Reak Show provided the link to. Basically, the one hose goes where it went before, just downstream of the air cleaner box, and the other tees into the PCV hose. FWIW, when I teed into the PCV line I also installed a catch can which has caught about 1/8 cup of sludge over the last 1,500 miles.
Wow, that's a laundry list of items to do all at once. Some seemingly simple things but...
Is your fuel filter installed correctly? I don't think it's possible but if it was backwards...
Also P0100 and P0101 are very rare codes. Double-check your 7th injector wiring and do not use butt connectors, only solder the wires. Too many friends of mine have had odd codes because their wiring came loose. The inability for the ECU to see the MAF signal will kill the engine, every time.
UPDATE: Took it to the shop to take a look at it....I was out of ideas. Turns out I nipped one of the MAF wires when I cut the electrical tape around the rubber boot protecting the wire bundle in the engine bay.
Now she runs perfectly. Even got it tuned....9.5PSI of boost and a little over 200HP.
Nice! Hey a couple of dyno questions for ya as you and I are some of the rare people who have stuck a 4Runner on a dyno in the past 10 years.
Do you have an auto or a manual? I have an auto and couldn't get a good 3rd gear pull where the final drive ratio is 1:1 due to the speed governor cutting fuel at 107 MPH, around 4800 RPM. Did you encounter this issue?
Did you get a lot of pushback of "oh we don't do Toyotas" when trying to find a dyno? Shops were turning me down even for just a plain ol dyno run with no tuning sessions.
I have auto. I honestly have no clue. Just from observing nothing really significant until she went into 2nd then cut out at about 5700/5800rpm...dunno what the mph were.
Haha....yah there isn't a lot of shops on island with a dyno to begin with and most of the shops are picky about what cars they do. I got lucky and made friends...the guy who did mine mostly does Hondas but took on my project for a little more than he charges the other guys.
Any printouts of the dyno run? Always fun to see a supercharged engine torque curve.
Can someone confirm this check valve direction? Is what I have pictured correct??
Where is everyone installing their 7th injector AIC? I was going to install in the kick panel, but there is something in the way.
