Brian.
Member
Sure there's smarter people then I with computer/software understanding that could hack it...
Yup, been done years ago... info is out there for anyone to find (I mean, I was able to find it... and not on an obscure site/forum either).
Going to need to know year/trim level in order to help with a wiring diagram.I have been wondering why my 4WD was not functioning for the longest time. I finally took a look and found that the two wiring harnesses on the end of the transfer case were not connected to anything. Also found out the 4wd stick isn't connected to its wiring harness as well. Anyone have wiring diagram or better yet a clear description where the wiring for the transfer case needs to go? Pictures below:
Jus out of curiosity, does anyone know why/how Tacomas supposedly squeezed an extra ~10hp out of our motors when they were new?
Picture not visible or there for meWhat is this plate covering? Im assuming for some accessory that my base model doesn't have?
Check and clean all the ground points in the engine bay. Check/clean your battery terminals and connections.OK. I have a 2000 4runner. Out of no where it will not start. All i get is a clicking noise. We have put on brand new starter, checked and changed the battery. Tried to jump it off. Checked the relays and fuses and made sure the connecting wires to the starter we good. Still will no luck!!! Can anyone please help me out here.
Sent from my SM-S908U using Tapatalk
I guess my attempt to use dropbox has failed. Updated with an attached image.
Now I'm curious...I can see it now, but have no clue what that might be for.
If you are only concerned about clearing those tires at ride height then a suspension lift is all you need. If you are going to Offroad or flex any then you’ll need to clearance the body and probably the bumper. Here’s a good read that should explain it better Clearing 35” Tires at any Ride Height - Coastal OffroadI’ve got no time on my hands, just like all of you. So, here’s the question.
I bought a 2002 4runner SR5 Sport. Great right? Not yet. Second day after getting it home the upper ball joint decided 230,000 miles was enough. It’s sitting in front of garage. Where’s the question right?
I have a gmc k1500 sitting right next to it. The gmc had new BFG 285/75/16 on it. The truck needs new cv axles then it’s going to be sold. Do you see the trade coming up?
I want to put the new BFG’s on the Toyota.
What is the absolute “right” way to achieve this? I’m guessing from what I’ve read that I’ll need:
Quality 3” Suspension
Performance upper support arms
1 inch body lift
That’s where it gets clouded. Is anything needed for steering adjustments? Front differential? I don’t know. I can only afford to do this one time. The sale of the GMC is going into the Toyota.
That’s where I’m at. I have some mental issues that greatly reduces my ability to visualize a project from start to finish. I used to. I was a carpenter for 25 years. I could build a given project in head from start to finish. I would figure every detail in my head. Now, I can’t. I can do anything, but it has to be broken down into steps. It sucks, but that’s just what it is. I’ve read about every post there is regarding this project, but I’m afraid of skipping over something and having to redo what was already done.
Hey, if your still reading this your attention span is better than mine.
A list of what’s needed, in order, would be awesome. I don’t need super details, I can figure things out if I know what the following task should be.
Thanks. Every single person is busy working and living. If you don’t have time or are in the same boat I’m in, no problems. I pretty sure of I keep reading through the posts I’ll figure it out. like I said, I’m lazy.
That's about the long and skinny of it. Would be a good time to do lower ball joints too just for the preventative measure. Longer brake lines will be needed and longer sway bar links too (1 inch longer for both if I'm not wrong, there's a couple ways to go about this). Extended parking brake bracket is a good touch to have so you don't stress out the cableI’ve got no time on my hands, just like all of you. So, here’s the question.
1 inch body lift
Why is it that my 2001 T4R 3.4L calls for the YZZD1 oil filter whereas my Dad’s 2003 Taco 3.4L calls for the YZZD3? I’ve been running the D3’s for the last few years but really want to know what the difference is and why Toyota decided that.
well as you have discovered ....you can run the D3 on the 4runner.....I do on mine. Difference is you pick up more filter area and about 1/4 qt more oil. There is no difference other than that, that I know of
But why toyota had a different filter for the 3.4 taco I dont know. Is there more frame clearance ? A bigger filter for a "work" vehicle ?
I read some commentary on another forum post that discussed potential differences and how running an oversized filter could potentially harm your engine as opposed to providing a better filtering component. I don’t know what to believe. I’ve ran the D3’s for years and would like to believe they filter “somewhat” better than the D1’s. Only logical explanation would be what you said about different framework. Thanks for the input!
