a4runner97
Soooo many shifter clearance issues. Thought the short shifter was going to help out but nope. Looks like I'll be bending the trans shifter and front reduction box shifter and cutting down the two rad design shifters.
I have pics in my thread somewhere of bending mine. It took a few attempts to get it where I was happy.
I ended up bending the lower part a little more even after this pic
Thanks! That's what I needed. I bent the Lower part already. Closer to fitting it'll fit after I cut the 3 rear shifters down I think I'll make them all even.
Getting closer. Dropped off my driveshafts and it was done in less than 24 hrs. So those are in. Gotta make the crossmember, drain and fill the cases, and do the in cab stuff like shifters (which I'm dreading)
Woo hoo. keep it up. BTW do you have a build thread?
So did I **** up? Welding up the crossmember I noticed some fluid dripping. I didn't seal between the trans and tcase adaptor because there shouldn't be any fluid tranfer there right? But now I have a leak.
Was I supposed to rtv between the trans adapter and the transmission?
I had the sameish problem. I did use rtv from the adapt to the trans, I had fluid leaking from the lower bolts holding the adapter to the reduction box. A little extra rtv and it’s still sealed.![]()
Mines coming from the housing.
Yes. Did you RTV the trans to crawlbox coupling? That needs to be done as well.
For the reduction box shifter I found it easier to bend up a TrailGear shifter than the stock one - https://www.trail-gear.com/index.ph...ttransfer-case-shifter-with-knob/category/64/
Did you clearance for the 4.7 gears? Sometimes the case will leak after clearancing due to porosity in the casting...
That's the only spot I didn't rtv and the only spot it's leaking. Dammit
Well, since there's no RTV in there at least the coupling will come off easy. Sorry man.
In my research a lot of guys had fretting from the coupling. Some guys coat it with anti-seize first then RTV or Permatex The Right Stuff it. I skipped the anti-seize and used Ultra Gray RTV. I know [MENTION=135317]rkntoy[/MENTION] used The Right Stuff.
A few weeks ago I pulled the shifter and bore scoped the hole that goes from the crawl box to trans adapter. It allows a very good view of that portion of the case. Mine was very dry. Which surprised me since a lot of wheeling I do gets very steep and I thought that hole I left open would allow gear oil into that dry space. It hasn't. There was about 2000 miles on my rig since install when I checked.
Pull it and use something to seal it. If not your trans fluid will mix with the gear oil. Sorry you missed it man. There's not a lot of talk about it but if you search Pirate it's there.
