Bxmarauder
I have a Tacoma and would like to perform this before adding an amplifier, will this work for my truck TRD off road and is the procedure the same?
With PM turned OFF: Both the rear door and tailgate speakers are on; wired together in 'Series' @ 8ohms. When PM is active the (EDIT) tailgate speakers are not shorted, but rather, lose their NEG side signal wire (OPEN CIRCUIT) which then closes (via EQ relay) at the rear door speakers thus completing that circuit and allowing them to operate independently at 4ohms.
"See wiring diagram at the EQ Relay illustration: pictured with relays in N/C position (PM OFF)" If you follow it starting at the HU (RR-) wire #6 YELLOW. Path goes to the tailgate speaker v.c. then through the R-channel EQ relay, then through the rear door speaker v.c. and travels back to the HU (RR+) as completed! My diagram simply shows how to choose which speakers get manipulated by the EQ Relays and make the changes that will cause it to happen! Rgds
Party mode - there's a subject that doesn't get discussed much any more. Since I added a DSP to my factory base audio system, I don't really want or need to utilize party mode. So, I disconnected the connector on the back of the party mode switch. All four rear speakers still work. Now, if I want only the rear door speakers to work, can I just jumper the hatch speakers like [MENTION=83083]rigtec[/MENTION] did above?
Thanks Op. I did this mod to my 2013 4runnner SR5 with no jbl/navigation. On the head unit my wiring was a bit different. It has different harness plugs and locations. I am pointing to it with meter probe (pic below) I also used a pair of speaker wire harness for the rear door jumpers.
See pictures below.
Thanks for the detailed write up. I was able to find the right wire because you did a great job describing how to test for it.
I am pretty pleased with the sound after this mod. Just last week, I replaced the stock speakers. The subaru kickers for tweeters. 6x9 kickers in front door and 6.5 rounds in the back doors. Now the system rocks all the nice new speaks to the best it can.
Thanks again.
--Pat
See pictures below.
Thanks again.
--Pat
I just ordered the exact same speakers.
-Subaru Kicker tweeters H631SFJ101
-Kicker 6x9" 43DSC69304
-Kicker 6.5" 43DSC6504
Did the new speakers make a significant difference in sound? Do the new speakers provide enough bass on their own?
Yes, big difference. you might want to pick up some thin foam tape to help seal the speakers against the door panels I notice a bit of rattling when the volume high. I might go back and add some. The bass is ok, not great.
one tip on installing the door panels is lower the window. it's easier to get the top edge clipped back in.
PatSloan,
Did you have to buy speaker adapter/mounts for the front 6x9 doors speakers and the rear 6.5" door speakers? If so, where did you purchase them from? It looks like TacoTunes has front mounts that would work, but I really didn't see anything for the rear door speakers.
yes, i used the following. Had to drill a couple holes for the 6/9's
https://www.amazon.com/gp/product/B00IIC63P8
https://www.amazon.com/gp/product/B00IIC6CPE
and a harness
https://www.amazon.com/gp/product/B01GEIP7RW
