timing belt ebay kit???
Id recommend the one fenrisx posted. I just put this kit on my 96 a week or so ago and it was great, very convenient and its cheaper then buying from toyota even with my employee pricing.
ended up getting the kit from VOLKSTOY on ebay. was best price for all items oem plus i had a ebay coupon. do most people use everything in the kit?
Yeah, just replace everything the kit comes with while your in there. No sense in tearing it all apart again cause your idler bearing fails or some other small part you could have already replaced.
Also, I'm looking for a good DIY for this, so if anyone happens to have a link, that would be great if you could share it!
This is my favorite: 5vz-fe timing belt
One thing that nobody explains, if you are changing the hydraulic tensioner, then the BluePoint tool is useless as you have to take the A/C compressor off to get the tensioner out. The new one is already compressed so there is nothing for that tool to do. It only works if you reuse the old tensioner.
I changed everything but the seals. They weren't leaking so I left them alone. They had been replaced the previous time.
Thank you!
Thanks for that link the Durk. Following that totally makes it possible to do. after reading that I feel comfortable doing it even though I've never done this kind of maintenance before. Thanks again.
I'm looking to buy one of these, just wondering why NSK? What was the issue with the idler pulley that they offer?
Thanks!!
Spoke with Volkstoy, and they can provide Koyo but not the NSK. I will be making my order Monday, looks like a good kit with a fair price.
Supposedly the NSK is the same size as the OEM, which I believe is NSK and not Koyo. But when using the Koyo idler, as long as the tensioner is working correctly, I don't see it being a real problem using the Koyo idler.
ghengiskhan
