tmcintosh3
So I just ordered a 1.5" body lift from 4Crawler...pictures to come :hungry:
Here is what I think I will do with upgrading my rear;
If this does not get me to my desired height (eliminate my massive "anti-rake") of being roughly .5-1" higher in the front, I was thinking of adding a rear coil spacer.
I was only able to find Rancho and Daystar 1.5" or Daystar 2" Rear Coil Spacers
If I were to add a spacer to the above proposed rear end set up, would I need to upgrade my rear swaybar links and upper/lower rear links?
Thanks all!
ICON Extended Travel 2.0 VS Series Shocks - to replace my Bilstein 5100s
ICON 3" Overland Series Rear Coil Springs - to replace my 2" Sway-a-Ways
Metal Tech 4x4 4Runner rear suspension bump stop drop with Arc Swing Correction - because I have to
Stainless steel extended brake lines for the rear axle - because I have to
Thanks all!
