TMP's 2002 Build and Wrenching thread
February 18, 2017
The replacement Tigershark has arrived along with a little friend
https://flic.kr/p/XNa73vhttps://www.flickr.com/photos/152444593@N06/
https://flic.kr/p/YLJEpmhttps://www.flickr.com/photos/152444593@N06/
I had to get shorter bolts for the fairlead so that the winch would fit. Stock Superwinch bolts were too long to work with the AOR space provided.
https://flic.kr/p/XJBrBU https://www.flickr.com/photos/152444593@N06/
Cables nicely routed and ready to go wind on this line with proper tension...
https://flic.kr/p/XJBrEj https://www.flickr.com/photos/152444593@N06/
There is a car wash by me with a huge parking lot and some heavy duty lights in big concrete pillars so I rigged up on that, spooled out, put on the parking break and slowly winched the line in under steady consistent tension. It's nice and even on the drum.
https://flic.kr/p/YqJgxh https://www.flickr.com/photos/152444593@N06/
Got a sweet deal on a TJM recovery kit.... hence the yellow bow shackles.. only on for the photo op, I just carry them in the bag.
https://flic.kr/p/YLJQyE https://www.flickr.com/photos/152444593@N06/
and replacing the body ground with a 0 gauge (overkill, if I do the rest of the big 3 I'll use high quality 2 gauge)
Nice start to your build thread man.
There's no such thing as overkill when dealing with grounds. In this case bigger is better. I upgraded all my grounds as soon as I got my rig. Never planned on finishing the Big 3, just the grounds. After running my winch(Engo 12000) and blasting my bad ass stereo system for over a year now, I still see no need to actually complete the Big 3. Grounds are where it's at.
September 15, 2017
Ram Mount Dash Install & Strong-arm upgrade
Read this on here somewhere and decided to go ahead and give it a shot so I could mount my iPhone 6S somewhere usable without obstructing view. I use Maps & MotionX-GPS for offline for navigating in the back country.
I took a map class once and would like to start getting familiar with maps and compass again... maybe in the spring.
https://flic.kr/p/YK1xKU https://www.flickr.com/photos/152444593@N06/
Pilot hole... I forget what size I actually drilled this out to
https://flic.kr/p/YK1xMh https://www.flickr.com/photos/152444593@N06/
https://flic.kr/p/YK1xR5https://www.flickr.com/photos/152444593@N06/
Doesn't move at all on the street. Moves a bit offroad as to be expected but no way is it ever coming off of that mount! Phone is held in super tight!
https://flic.kr/p/YK1xPm https://www.flickr.com/photos/152444593@N06/
Ram Mount in action
https://flic.kr/p/YyALWE by https://www.flickr.com/photos/152444593@N06/
Rear lift gate, Strongarm with extra opening power upgrade - totally happy with these. They lift the Gobi ladder no problem.
https://flic.kr/p/YK1xVd https://www.flickr.com/photos/152444593@N06/
September 16, 2017
East Portal to Mammoth Gulch to Kingston Peak
This was a fun fall trip up to the big pull out before the trail gets rough to finish Kingston peak. I parked there for awhile and enjoyed the views and then headed back down..
Lefthand Canyon
https://flic.kr/p/YyAMg7 https://www.flickr.com/photos/152444593@N06/
Peak to Peak Hwy
https://flic.kr/p/Cxhpyf https://www.flickr.com/photos/152444593@N06/
Peak to Peak Hwy
https://flic.kr/p/CxhpH3 https://www.flickr.com/photos/152444593@N06/
Rollinsville @ East Portal Rd
https://flic.kr/p/CxhpRQ https://www.flickr.com/photos/152444593@N06/
https://flic.kr/p/ZfAbtY https://www.flickr.com/photos/152444593@N06/
https://flic.kr/p/ZfAbMU https://www.flickr.com/photos/152444593@N06/
Airing down for Mammoth Gulch ascent
https://flic.kr/p/Zz5PGC https://www.flickr.com/photos/152444593@N06/
* more to come......
I agree... it's just that have you seen the size of 0 gauge!!! I guess i didn't really think it would be that big in diameter.... I am probably going to use the rest of it to replace the engine ground and call it good.
Next year I would like to go to a higher output alternator and dual battery system so i can put accessories on battery 2. Planning more lighting, fridge and inverter to increase campability!
I have 0 Gauge run through my firewall to a distro block under the drivers seat. 4 gauge from there to feed my 2 amps. I only used 2 gauge to increase my engine and battery grounds though. lol
If your gonna have constant draw a second deep cycle is the way to go. You could charge both with the stock alt but something with more amps would be way happier bringing the deep cycle back up. Running a small solar cell to help keep it closer to topped if would also be needed IMO.
I had a dual set-up in my 88 Van. I basically lived out of that thing for 5 years so having an inverter and fridge was huge. I installed an old school Cole Hersey Solenoid instead of the fancy electronic battery isolator. The new ones are pretty sweet but if they fail your stuck. If the Cole Hersey fails it fails closed so there in no way for the starting battery to be effected. Just my take on a subject you can read about for weeks.
ghengiskhan
