Toyo Open Country?
They've worn pretty well so far. They handle OK and noise is not too bad for an aggressive-lookiing AT. The only off-road I've done so far is driving across some fields/ pastures and so-far-so-good. They did seem to pick up and hold a lot of mud though. They also seem to do pretty well in the wet. I haven't driven on ice or snow with them yet.
I had Firestone Destination AT's before these. They out-performed the Toyos in pretty much every scenario on the street and were much quieter. Both performed well off-road....at least with the relatively mild stuff that I do. The Toyos look way better though.
This pic probably shows the tires best:
I have the E rated AT2. I like them ok. They look good, but not as good as Duratracs. I mainly bought them because they had a tread wear warranty.
I have about 5k on them so far and they are getting noisier but I need a rotate and balance.
Performance and handling is stellar. Dry, wet, mud, grass, are all good.
I live on a dirt road and these things pick up and throw gravel like crazy. I assume all ATs do that, but if there are some that don't I want them.
I
Oh, and the E rated LT version has a more pronounced sidewall pattern and deeper/wider tread than the P metric.
Your truck looks great! Good insights also, thanks. I have a 2014 SR5 with a 2-3" ARB Old Man Emu suspension lift, and I'm about to install the same exact tires as you (Toyo Open Country ATII 28570R17s) on Konig Counter rims. I know our equipment is different, but on your set up, did you experience any rubbing? Did you have to adjust caster and move the wheel well lining at all?
Thanks!
D'Angelo
