Saved
Interesting information
http://www.settraining.com/content/course-codes/12_07_HS_Toyota_Engines_and_Synthetic_Oil1.pdf
It's interesting that they state the 2TR-FE (2.5L I4 engine used in Tacomas) is listed as not compatible with synthetic oil, as an absolute statement.
It's probably more correct to say it's incompatible with 0W20 synthetic.
What say [MENTION=48413]Quentin[/MENTION] and [MENTION=66316]1engineer[/MENTION]?
The 10K deal has me feeling a little uneasy. Im @ 12K now. What I did was replace the oil filter w/ a Toyota genuine @ 5K and then I added a quart of 0W20 synthetic & then took it in to the dealer for the 10K. I said nothing and neither did they. Guess the mechanic didn't notice that the filter had been changed.
The Tacoma uses a 2.7L. According to the sheet, it does use synthetic but at the shortened 5000 mile interval. I don't know what weight oil it uses, but synthetic is surely OK in it. The 1GR in the tacoma, which is an older revision of the 1GR rather than the one in our 4Runners, ships with conventional oil at a 5W-30 weight (IIRC) rather than 0W-20. I would say that you are correct in that you CAN use synthetic 5W-30 oil in the Taco 1GR, but you cannot use a synthetic 0W-20.
I'm debating what to do with my 4Runner. I'm at around 6000 miles on this change and 15 months since the last change. I hate to dump $50 of oil out if it still has 5000 miles left in it.
I suspect you are correct Jan. The target audience does not need to be confused. Same for the Tacoma and 4Runner V6 engines. I will defer to [MENTION=44268]Quint[/MENTION]in though.
Why? Do you do extreme service in your vehicle? I won't criticize I am just curious why you would go against the advice of some pretty good engineers unless you are towing daily or traveling the desert for 100's of miles.
Another interesting item is that the 1GR-FE for the T4R, FJ and Tundra are synthetic, but the same engine in the Tacoma is conventional. I assume the engines are the same.
As a matter of fact, yes I do. We live in So Cal and often cross the Mojave desert in order to get to Vegas and Laughlin. We also have a pretty heavy jet boat that we take out quite a bit. Lastly, I'm in the automotive industry and way too many times I have seen oil filters stop filtering or even fall apart at 8k and 9k
Car blowing white smoke is burning coolant, probably nothing to do with the oil they run or change interval.This post actually made me feel a little more comfortable about my oil. My main concern like N2Glock was that the oil filter would be unreliable after 8k. I don't like going 10k between changes but I guess I'm old school. Feels like I'm going to be one of those cars blowing white smoke all over the road or have hunks of metal in my oil pan.
Now to get off topic I was wondering something today. My father is really old school when it comes to cars, he always complains when I let my tank get to near empty. His reasoning is I will suck up the gas which has been sitting stagnant on the bottom with trash. I know the gas mixes and sloshes when your driving. But is there any truth to this?
What trash? The only crap I have encountered in fuel tanks is rust in the TOP of metal tanks. Gasoline mixes pretty readily. The only thing you risk is damaging a fuel pump by running it dry, as it uses the gasoline for cooling.
Blowing white smoke is usually an indication of burning oil, not coolant. Oil burning in cars with low mileage often can be attributable to oil change intervals, but not due to following the manufactures recommendation (it is amazing how many people don't change their oil as recommended).
David
David
Are you sure about that because every engine I've worked on that burned oil was producing blue/grayish smoke. And coolant/water leak is usually white smoke like Jeremy said.
In reference to this:
Yes. If you've got a car that's puking tons of smoke, yes you can tell the difference between grey smoke from oil and white steamy smoke from coolant contamination. If you are a trained mechanic checking a car you can look at it and tell pretty quickly even if its not much smoke. If you ask most people what color smoke they see coming out the back of a car that's burning a little oil as its driving down the highway in the daytime, they will say white, they don't realize the difference till you compare it side by side.
When you start getting coolant in the combustion chamber the end is coming rather quickly - you're not going to drive like that for a long time before you have it repaired or suffer catastrophic failure. Burning oil can go on for a real long time w/o repair as long as you don't run completely out. The guy in the parking lot at work or the guy in your neighborhood that you see driving day in and day out for years puffing a little "white" smoke is burning oil, not suffering a blown head gasket.
This wasn't a diagnostic question - "My 4Runner just started blowing white smoke, what is it?"
He's describing all the vehicles he sees driving around day to day that are blowing whitish smoke out the exhaust - mostly what he's seeing is cars that are burning oil. The way Jeremy's reply was worded it read (to me) as if those cars you see driving around all the time puffing "white" smoke out the tail pipe all have blown head gaskets - can't definitely say how things where you are, but that's definitely not the case where I am.
YMMV
David
